Results 1 to 5 of 5
Thread: Fault code advice 1.8T: Last post please
    Paid Member Finite's Avatar
    Nov 2004
    Northamptonshire
    1,931
    140
    Default Fault code advice 1.8T: Last post please
    So I've found another A3 8L 1.8T, but this one has only been off road 2 months and is a run out 03.
    It seems to run static ok, but has frequently lit the EML and lately EPC. The DIS unfortunately unreadable.
    4 Faults Found:
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    17925 - Main Relay (J271): Electrical Malfunction
    P1517 - 35-10 - - - Intermittent
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-10 - - - Intermittent
    Not much recent service history, but the oil didn't smell to bad and the top end is quiet at 90°C compared the the 150K motor I looked at before.
    Not too concerned about the Pressure Drop, but the Fuel Trim: System too Rich is a bit of a concern.
    1989 5dr MK II 8v Helios Blue Bodyguards® 4 Nitrile Edition. 21 years of ownage.
    Nov 2004
    Northamptonshire
    1,931
    140
    Search results better this morning with the right terms.
    It could all be simple as the dipstick tube is loose and can be pulled up. The air filters must be over due along with the oil, but it could be expensive also.
  3. #3
    Nov 2004
    Northamptonshire
    1,931
    140
    Right I guess this is the crux of the matter. How likely is it to pass the emissions with this:
    It is an alleged low mileage engine. No sign or smell of significant over fuelling at the exhaust or hunting.
  4. #4
    Nov 2004
    Northamptonshire
    1,931
    140
    This might be a go again. As I've read these fault codes are associated with limp mode. Is it possible to have them without limp mode?
    Cheers.
  5. #5
    Jul 2006
    16,363
    3,002
    Dump Valve is fubared or there is a leak in the charge pipe such that the system cannot achieve desired load and you might find your Lambda control is at -25 or attempting to pull fuel put at the limit, due to a poor FPR or lack of air measurement from the MAF.
