Results 1 to 3 of 3
Thread: ABF crankshaft oil seal
    CGTI Graphics Designer
    Aug 2009
    Wiltshire
    1,787
    55
    Default ABF crankshaft oil seal
    Hi all,
    Pulling the box out of my ABF'd Mk2 and whilst its out I plan to replace the crankshaft oil seal as I suspect its leaking.
    Wanted to check if its just a case of unbolting the old one and replacing? Is any sealant required and is it worth going genuine? Not a job I fancy doing twice
    Looking at this one as I'd rather not have to press a new seal in - http://www.veedubmachine.co.uk/crank...addy-feli.html
    Thanks!
    Jul 2006
    16,436
    3,022
    As above. Use the tool that comes with it. Makes life very easy!
  3. #3
    Aug 2009
    Wiltshire
    1,787
    55
    THanks for the reply Ed - tool that comes with it? So no gasket sealant or anything required.
