1989 Jetta carat starts... sometimes.
Discussion in 'Engines' started by montoni, Feb 14, 2018.
  1. montoni New Member
    New York
    I have a weird issue where ill turn the key of the car and the fuel pump won't prime, then I try another time and it will turn on. 5 minutes after that it primes and starts but if I wait a few hours it does not prime. I replaced the relay and fuse. Im stumped.
  2. notenoughtime
    Try bridging the relay after its left for a few hours maybe a sticky pump
  3. montoni New Member
    New York
    sticky pump would mean bad one? I have a parts car with a working one i might just slap that in.
  4. notenoughtime
    Bridge the relay first before changing pump
  5. montoni New Member
    New York
    what do you mean bridge the relay?
    an easy way is swap a 17/18/100 relay into the fuel relay slot, fuel pump should then always come on with ignition
  7. montoni New Member
    New York
    ok did that and the fuel pump went on and cranks but now dosent start still.
  8. montoni New Member
    New York
    REALLY WEIRD, if i adjust these screws and crank it it sometimes starts.
  9. montoni New Member
    New York
  10. montoni New Member
    New York
  11. Finite
    Northamptonshire
    Is anything else intermittent on the electrics? The ignition switch could be on its way out.
  12. montoni New Member
    New York
    yea i just changed it out with a good one i had from my old car, still having weird issues.
  13. montoni New Member
    New York
    I redid the grounds under the hood, the ignition switch, took out the old ****ty alarm system and crimped the ignition wires back, changed the battery and dist, cap and rotor and STILL have a intermittent starting issue.
  14. rubjonny
    have a look at the ecu relay next if its an 8v, 32 in slot 3. put the original fuel relay then listen/feel the ecu relay every time you switch on the ignition, if it doesnt click at the same time it wont start/prime then you have found the culpret :)
    you can use a mk3 golf one #30, those are cheap and available at the dealers
  15. montoni New Member
    New York
    Yo your a life savor!!!! I think it worked!!! now i just gotta test it out this has had me stumped for 1 months
  16. rubjonny
    good stuff, keep us informed :)
