are all mk3 golf gti 8v's basically a 2E engine with codes ADY, AGG, AKR & ABA etc ?
Discussion in '8-valve' started by Mal C, Feb 17, 2018.
  1. Mal C Forum Member
    Yorkshire
    as per subject are they all same if I need 2E distributor for a mk2 coversion ?
  2. Toyotec
    The 2E runs a 4 window dizzy and acts as a crank trigger.
    ADY and AGG engines, run a crank trigger like an ABF engine, and the dizzy carries 1 window for cylinder recognition only.
  3. Tristan
    The "non 2e" engines have a different diameter dizzy to the 2e, larger than Digi for example, but you can fit a 4 window Digi style one with an easily machined adapter. And use the matching intermediate shaft.
