Smoke from behind the engine
Discussion in 'Mk2' started by albertrll, Feb 18, 2018.
  1. albertrll New Member
    Hello everyone!
    I'm restoring my 1990 golf GTi 8v MK2. 2 weeks ago we started up the engine after 13 years of hibernation and started really smoothly. The problem comes when the engine has been started for about a minute. A white smoke starts to appear from behind (manifold zone) and smells like burning oil. The thing is that once the engine is turned off, the smoke continues.
    I leave a video to see if you can make an idea of what I'm trying to explain!
    https://youtu.be/36VLCnE1wCk
    Hope anyone could help,
    Thank you very much!
    Looks like your rocker cover is weeping oil onto the exhaust manifold.
  3. albertrll New Member
    The problem is that I have already changed the gasket..
  4. notenoughtime
    Essex
    Was it the correct one as there are two! Cork or rubber if the wrong one is fitted it will leak
  5. albertrll New Member
    I fitted the rubber one! :)
  6. Tristan
    Did you change the studs for the proper non shouldered ones?
    Other possibilities are a bad camshaft oil seal, or a distorted rocker cover?
  7. valvemiester
    Trowbridge
    Is it old residual oil on the manifold because until it's burnt it all off or you decrease it it will still smoke.infact even when you have decreased it it will still smoke until everything has burnt off
  8. albertrll New Member
    Hope it is just that but yesterday the engine was turned on for about ten minutes and there wss still a lot of smoke coming out. Do you think there is still oil there?
  9. albertrll New Member
    I think I have found where the problem comes from but I don't know what is due to. There are some oil spills in the manifold, do you guys know what causes? Bad gasket, the screw is not tight enough....
    https://imgur.com/a/Z2Ykn
  10. Savagesam
    That looks like is just run, if so, leave it running, let it burn off and then check it :)
