A4 1.8t rough idle
Discussion in 'General Vehicle Chat' started by Craigcorson, Mar 11, 2018.
  1. Craigcorson
    Craigcorson Forum Member
    Inverkip
    Got a 2005 a4 cabrio, again....
    This one has a rough idle with the occasional yellow light.
    Had initially thought it was the PCV valve UFO thing next to the bulkhead.
    Replacing that has improved it slightly but after searching the internet most people say try and take the oil cap off when running.
    With the old valve I could, just. With the new one its much worse.
    Got a couple of spare coil packs which was a doh moment. Should I be looking for another valve or a vacuum leak?
  2. Savagesam
    I'd go vacuum leak, mine was horrible at idle when I had one. I thought I'd broken something but it'd just got brittle with age and cracked.
  3. GVK
    Disconnect the MAF see if idle improves could be dead MAF or vac leak as above.
  4. Craigcorson
    Inverkip
    problem solved, 3.20 check valve located underneath the inlet manifold
    woohooo
