20VT Boost and injector leaks
Discussion in '1.8 & 1.8T' started by Finite, Mar 20, 2018.
  1. Finite
    Northamptonshire
    I'm finally getting around to sorting this out judging by the oil I thought I'd start with 6
    Tried a new seal, but there is far too much play in the mickey mouse tinpot union. I'm going to try some self amalgamating tape on it tomorrow since large heat shrink seems not to be stocked in the UK. Are these pipes NLA now?
    I also have a seal, pintle, filters kit for the injectors, but am I likely to need seats as well and would that be more of a manifold off job?
    Cheers.
    whats the car, year and engine code? its worth trying VW before the internet, I needed a lower intercooler boost hose for our bora and from VW it was cheaper than all the crappy used hoses on ebay
  3. Finite
    Northamptonshire
    It's an 03 A3 8L AUM. I could see the part no. on it this morning it's definitely the so called upgrade part 06A145790C.
    I did find some UK stocked 76mm heat shrink so I'm going to give that a go first. Seems like the hose is pushed a bit too far onto the pancake and is under too much tension imo. Thought about making a support out of a 63mm exhaust bracket with some twisted strip steel off of one of the M10 holes on the back of the block, but cost wise probably not worth it as it would probably need a custom heat shield jacket.
    06A145790C is available at 63+VAT, so yeah I would try to get what you have fixed up first if you can :)
    on the bora pipe I replaced it had the same clip type fitting but the nibs the clip locks over were all worn away so it kept popping off
  5. rubjonny
    sorry I missed your other question, usually the seats are fine but they are only 3+VAT from the dealer if you're worried 06b133555H
  6. Finite
    Northamptonshire
    Cheers for the prices, no worries. The nibs are ok on my hose, but theres 1mm plus of play. The robust long term solution seems to be to cut the female socket off flare the pipe cut the male off and use a coupler plus short section of hose.
    I might get those seats as insurance against doing it twice.
  7. Finite
    Northamptonshire
    Well it was worth a shot, but only a slight improvement with the heat shrink.
  8. Finite
    Northamptonshire
    Ordered one of these from Creations Motorsport for 45
    Hopefully it will do the job the end is machined instead of pressed.
  9. rubjonny
    pretty bargainous price for a custom part like that, let us know how you get on :)
  10. Finite
    Northamptonshire
    Will do. I'm fully expecting them to send the wrong colour hose even though I sent a message about it within a minute lol
  11. Toyotec
    Let us know how you progress with this.
    With 20vTs they tend to commonly loose boost via the recirc also. However as they get on with age, other places can also leak.
  12. Finite
    Northamptonshire
    Fitted part of the hose today. The silicon hose was a non starter as it's not really to pattern and lacking flexibility so I had do what I was hoping to avoid and to cut the socket off of the OEM hose.
    It's a very simple process. One nick in the skirt with a hack saw and it literally tore & peeled off when twisted around an old pair of side cutters.
    It's put a bit of slack into the connection, but moved the hose closer to the block. Primarily I bought the package to avoid taking it apart to size the fitting which I believe is 64&54mm and £25 on it's own.
    Unfortunately the noise is still the same from 2000rpm which along with some traces of aluminium makes me think the noise might be the turbo itself. On the bright side it did pass its MOT earlier in the week.
  13. mr.brown
    Sunny Surrey
    Let me know if you need a turbo - I have two from AUMs that I won't need.
  14. Finite
    Northamptonshire
    Thanks, that will be a great help. I might take it somewhere to nail this down as I don't have the time now and want to get on with the Golf.
  15. Finite
    Northamptonshire
    Right so I have my own vagcom setup now instead of borrowing. Logged these values this morning. Chopped to fit I've highlighted a few lines, but I've no idea what normal values are. I did also fit a new genuine DV to no avail. Thanks in advance.
    Group A:'003Group B:'115Group C:'031
    Idle speedAir mass inThrot AngleIgnit AngleEngine SpeedEngine LoadSpec. BoostActual BoostLambda FactorLambda FactorBin. BitsBin. Bits
    TIME700-820 rpm2.0-4.5 g/s0.2-4.0%0-12 BTDCTIME700-6800 RPM15-150%990-1800 mbar<=1800 mbarTIME
    MARKERSTAMP /min g/s% °BTDCSTAMP /min% mbar mbarSTAMP
    117.17192029.1425.514.3116.361160159901000116.760.861
    118.47144016.3112.215.8117.67200067.79901180118.071.0161
    119.78224026.0616.921118.87168053.49901070119.280.9921
    120.98304017.641130.8120.18252063.99901170120.581.0081
    122.19184031.4772.914.3121.39284013.59901090121.791.0551
    123.51252065.581006122.692120102.316301260123.090.9841
    124.8332076.2891.415.8123.912760137.615601670124.310.9921
    126.13404094.3610020.3125.23520122.614801460125.620.9921
    127.334680109.9410018126.514240118.814801480126.930.9530.945
    129.54352078.9210012127.844960120.314401460129.140.8050.899
    130.85364014.78936129.953600119.514701460130.430.860.992
    132.0535207.616.733131.25360020.39901060131.650.9451
    133.3634006.755.938.3132.453480129901020132.961.0311
    134.5632807.175.938.3133.76336011.39901020134.181.0161
    135.9731206.815.937.5135.07320011.39901010135.570.9841
    137.1823605.564.730.8136.37308011.39901010136.770.9841
    138.38196014.7210.221137.58196051.19901010137.980.9921
    139.6196011.78921138.78196038.39901040139.181.0081
    140.9196011.94921140196032.39901020140.50.9921
    142.11196014.6910.621141.29192033.19901020141.710.9921
    143.41200037.4752.911.3142.51196045.99901020143.010.9381
    144.62212050.611006143.822040102.316201280144.220.9691
    145.93228034.9720.810.5145.122160130.816201550145.5211
    147.34232035.4721.615.8146.43228057.99901200146.830.9141
    148.64244063.831003.8147.842360100.815801260148.240.9061
    149.85260062.331004.5149.052480134.615901630149.450.9530.945
    151.05268065.441009150.252600129.315801600150.650.9380.945
    152.37264012.113.90.8151.45272079.79901270151.871.0081
    153.7725204.924.30152.76260012.89901030153.281.9911.047
    154.9724405.835.10.8154.17248012.89901010154.571.9911.047
    156.1923205.895.11.5155.39240012.89901010155.791.9911.047
    157.522406.925.512.8156.59228012.89901010156.991.9910.797
    158.8220024.9215.720.3158220049.69901000158.41.0161
    160.1122007.087.122.5159.21220059.49901140159.610.9451
    161.32212075.923.3160.51216022.69901030160.9111
    162.62208010.728.221.8161.82212020.39901010162.220.9841
    163.93204022.2515.720.3163.02204029.39901000163.440.9921
    165.24208031.2819.613.5164.33204062.49901100164.8411
    186.66184023.5815.717.3185.86160058.69901070186.260.9841
    187.97220017.031122.5187.06200062.49901150187.4611
    189.17232013.679.424188.37224035.39901050188.771.0081
    190.3724006.694.324.8189.57236034.69901020189.970.9841
    191.69164015.3310.618.8190.79208014.39901020191.291.0311
    192.9172012.118.619.5192.09164046.69901020192.50.9771
    194.2184021.0614.118193.4176046.69901020193.811
    195.51200023.514.919.5194.61188060.29901100195.0111
    196.82220026.4415.720.3196.02208060.99901140196.420.9921
    198.02240033.5818.821.8197.22224063.99901170197.621.0081
    199.24208010.5610.219.5198.42248066.99901280198.8411
    200.44204029.6918.815199.64196065.410201070200.041.0231
    202.45228028.5816.520.3200.84212074.410201250202.050.9841
    203.86240026.4215.721202.95232061.79901210203.360.9921
    205.06248018.9712.225.5204.26240052.69901130204.660.9771
    206.28248015.7810.625.5205.47248041.49901070205.871.0081
    207.48252014.4410.226.3206.68252035.39901040207.080.9841
    208.79260052.3930.217.3207.88252032.39901030208.290.9771
    210.1280035.832022.5209.192680101.513701410209.70.9691
    211.324409.613.90.8210.5280037.69901150210.90.9381
    212.7122002.033.52.3211.81188012.89901020212.311.9911.047
    214.1121605.114.32.3213.22220012.89901010213.711.9911.047
    215.4321206.115.126.3214.512160129901010214.930.8990.797
    216.63212020.5613.322.5215.83216038.3990990216.221.0311
    217.94216015.9410.622.5217.04216048.19901060217.540.9691
    219.25220030.2519.220.3218.45216039.89901040218.851.0231
    220.56228050.47609.8219.75220077.412301240220.1411
    221.76240062.141003.8220.962320121.816001480221.360.9841
    223.1724809.148.225.5222.162440133.112701520222.670.8831
    224.3824809.757.525.5223.57248027.89901040223.970.931
    225.6824404.283.932.3224.88244022.69901010225.281.0081
    226.9923604.223.532.3226.082400129901010226.50.9611
    228.1923605.114.332.3227.39236011.39901000227.791.0621
    229.4123205.284.731.5228.612320129901000229.011.0391
    230.7222405.814.71.5229.812280129901000230.211.0081
    232.1322005.564.72.3231.21224012.89901010231.611.9911.047
    233.4221205.474.72.3232.62216012.89901010233.021.9911.047
    234.6420805.284.72.3233.82212012.89901010234.241.9911.047
    244.8196030.9724.715.8243.98184030.89901000244.40.931
    24620808.585.521.8245.2204072.99901220245.60.9451
    247.2119603.893.92.3246.4212020.39901020246.810.9611
    248.51164023.8920.415.8247.71160012.89901010248.110.9061
    249.82180028.9219.614.3248.92168075.211501130249.4211
    251.04192024.1414.117.3250.22184078.910801240250.620.9921
    252.33204025.2515.718.8251.53196065.49901160251.930.9921
    253.55220036.8121.615.8252.73212072.212301180253.151.0311
    254.84176015.1111.417.3253.95224053.49901270254.441.1721
    256.15192038.5899.69255.26184064.712101050255.751.0391
    257.37204050.311006256.55196010915501340256.970.9921
    258.67216018.428.614.3257.872080127.815301520258.2711
    259.9821603.924.723.3259.08220024.89901120259.580.9531
    261.19216013.479.422.5260.38216018.89901010260.780.9381
    262.49224047.3193.313.5261.69220045.99901010262.091.0551
    263.71236063.28986262.892280118.815901420263.310.9841
    265240010.694.725.5264.11240066.29901270264.60.8911
    266.3124005.584.727.8265.42240017.39901020265.910.9381
    267.5323605.674.730266.71236016.59901010267.111.0311
    268.8223606.615.530268.02236014.39901000268.421.0311
    270.1423607.926.326.3269.242360159901000269.740.9921
    271.3523209.567.123.3270.54236019.59901000270.941.0081
    272.7623206.425.129.3271.752320159901010272.250.9921
    274.0623209.067.124273.16232015.89901000273.561.0081
    275.2723206.035.130274.45232021.19901010274.871.0081
    276.5723205.474.731.5275.67232012.89901010276.170.9841
    277.8823205.584.731.5276.98232012.89901010277.481.0081
    303.4319205.194.33302.53204013.59901020303.031.9911.047
    304.7418004.863.93.8303.83188013.59901020304.321.9911.047
    306.0517204.223.53.8305.23176013.510001010305.631.9911.047
    307.3515203.423.14.5306.45164012.89901010306.951.9911.047
    308.6613203.142.75.3307.74148011.310001010308.161.9911.047
    309.978802.1720309.06128011.310001010309.571.9910.797
    311.1714803.943.14.5310.3792013.510001000310.770.8280.797
    312.469202.6921.5311.57124013.510001000311.991.8031
    313.6810402.6124.5312.88144014.310001000313.281.0081
    314.99248044.0630.620.3314.1100015.810001000314.590.9771
    316.21316021.255.90315.39280096.210301330315.791.0231
    317.62220029.2517.318316.6126801210001090317.10.9451
    318.8222407.756.323.3318.02228050.410001160318.410.9531
    320.13228016.0610.223.3319.22224035.310001020319.730.9841
    321.3322802.083.92.3320.53232036.110001040320.931.0081
    322.6416004.473.118.8321.73184012.810001030322.141.0391
    323.8416003.222.715.8323.0416001510001030323.441.0391
    325.1515603.672.425.5324.25160013.510001010324.750.9451
    326.3716003.922.725.5325.5515601210001000325.951.0391
    327.7716005.063.523.3326.7716001210001000327.2611
    329.07168021.7514.917.3328.17160021.110001000328.570.9381
    330.29188022.8614.518.8329.49176065.410001100329.891.0081
    331.49208047.9498.47.5330.68192067.711001160331.081.0081
    332.8240018.7211.821.8331.892160125.616001480332.30.9921
    334.11256067.7899.211.3333.2240065.411501120333.61.0231
    335.4296073.3610012334.612720134.6157016303350.9921
    336.72332081.4210013.5335.823040128.615101540336.220.9530.945
    338.03368084.9210015.8337.233480126.314701490337.630.9380.945
    339.34400090.1910018.8338.543800119.514701460338.940.9450.945
    340.65428096.3110018339.84408011814601470340.240.9380.945
    341.964520102.3910018341.054360119.514701480341.560.930.922
    343.164760107.8910015342.364600119.514601470342.760.9140.906
    344.385000111.0610020.3343.564840117.314301430343.960.8910.891
    345.68472015.945.93.8344.865080115.814101410345.270.860.984
    376.34244016.3311.815375.54244013.510001020375.941.9910.797
    377.65240022.6913.723.3376.74240051.19901030377.161.0081
    378.85240011.584.327378.05240043.69901090378.450.9611
    380.1623205.224.31.5379.27236012.89901020379.671.0231
    381.4822405.444.71.5380.68228013.59901010381.081.9911.047
    382.6820005.314.32.3381.88220013.59901020382.281.9911.047
    383.9921605.584.32.3383.081560129901010383.491.9910.797
    385.219204.833.93384.39184014.39901000384.791.9911.047
    386.421205.724.72.3385.6220013.599010103861.9911.047
    387.620405.114.38.3386.8212013.59901010387.21.9911
    388.92220051.781008.3388.02208037.61240980388.420.9771
    390.13252065.251003.8389.332320130.816001530389.720.9840.961
    391.54292071.510010.5390.632640133.815701610391.030.9450.945
    392.74324080.5810011.3391.943040128.615101530392.340.9450.945
    393.94356082.9210015393.143360128.614901490393.540.9380.945
    395.15388090.4710018394.353680121.114701470394.750.9380.945
    396.37420095.9710018395.554000119.514701470395.950.9380.945
    397.674520103.0610018.8396.774320118.814701460397.170.930.93
    398.884840107.1199.614.3398.08464011814501440398.460.9060.914
    400.29508019.586.72.3399.394920116.514201440399.790.8990.891
    401.7316010.114.71.5400.79448011.39901110401.191.9911.047
    425.0220005.224.32.3424.13204013.59901010424.621.9911.047
    426.3319605.174.33425.52200013.59901010425.931.9911.047
    427.6418004.863.93.8426.83188013.59901010427.231.9911.047
    428.8316403.783.54.5428.04172012.89901010428.441.9911.047
    430.0610801.891.63.8429.24156011.39901010429.641.9911
    431.3614803.563.10430.56144012.89901000430.960.7580.797
    432.5710402.3620.8431.75108017.39901000432.171.5691
    433.7713203.222.73432.97144012.89901000433.370.9611
    435.08120010.258.216.5434.28124012.89901000434.681.1561
    436.28136023.3676.910.5435.48124061.79901000435.880.9611
    437.5152019.782.417.3436.68144089.514901140437.10.9691
    438.715206.86225.5437.9156016.59901070438.30.9531
    439.9114405.614.721439.11480129901010439.50.9141
    441.21144015.1111.416.5440.41140028.69901000440.811.1561
    442.52152011.97917.3441.63148045.99901030442.120.9771
    443.74160017.1712.218442.92156041.49901020443.321.0081
    444.94180013.259.818444.14164060.29901050444.540.9841
    446.1418008.283.13.8445.34180018.89901080445.741.0391
    447.35184012.1499.8446.55180012.89901010446.950.9381
    448.55204042.9297.310.5447.75188054.99901010448.150.9921
    449.86244067.531006.8448.952120115.816001380449.370.9841
    451.18284070.4210010.5450.262560136.815801630450.781.0081
    452.49312020.532.70.8451.583000125.614201500452.0711
    453.78268069.7599.610.5452.98252051.914401010453.380.9061
    455.1244014.473.50.8454.182760132.315501610454.60.8671
    456.322407.253.51.5455.49224012.89901050455.891.9911.047
    457.5122405.194.71.5456.71224012.89901020457.111.9911.047
    458.8222005.224.72.3457.91220012.89901020458.311.9911.047
    460.0221605.284.32.3459.212200129901020459.621.9911.047
    461.3321205.084.72.3460.422160129901020460.931.9911.047
    462.5321205.314.32.3461.73212012.89901010462.131.9911.047
    463.8520804.894.313.5462.93212012.89901020463.351.9910.797
    465.05212012.44922.5464.25208015.89901010464.640.751
    466.3621204.334.327.8465.46212029.39901010465.960.9841
    497.8419605.144.33497.04196012.89901010497.441.9911.047
    499.1519605.144.33498.24196013.59901010498.751.9911.047
    500.4519205.064.33499.55196013.59901010500.051.9911.047
    501.6619205.174.33500.86192013.59901010501.261.9911.047
    502.9819205.114.33502.06192013.59901010502.461.9911.047
    504.2716404.533.94.5503.47188013.59901010503.871.9911.047
    505.5813603.142.70.8504.69120010.59901010505.091.461.047
    506.813203.332.70.8505.98156014.39901010506.380.930.797
    508.0918805.194.33507.29164012.89901000507.691.1641
    509.41208041.089814.3508.49184013.59901010508.910.8210.828
    510.61284072.611009509.812280114.316101360510.210.9691
    511.82364053.3321.621511.023160133.115101550511.420.9450.945
    513.1324409.223.90.8512.22336010.59901160512.621.0471.047
  16. m1keh Forum Member
    Can you try to get a log from 1500-redline rpm at 100% pedal in third gear up a hill just to get a complete picture of the cars health?
    What exactly is your concern in terms of a noise? I'm assuming it sounds like a boost leak?
    This page is a handy guide for logging it is for tfsi's mainly but has some good pointers.
    http://www.goapr.co.uk/support/datalogging.php
    However I would replace group 31 in your original logs with group 114.
    But from your current data looking at time stamp 344.38 the airflow vs boost you are getting = 111g/s @ 5000rpm for 1430mbar boost. Which sounds reasonable for a stock 150hp 1.8t. I'd imagine at 6000rpm that will be up around the 120g/s region. So i'd say the log above suggests you don't have a boost leak unless it is quite a minor one...
  17. m1keh Forum Member
  18. Finite
    Northamptonshire
    Thank you. Some of it was up a long hill run up in third. I'm a bit reluctant to red line it as it may well have the original cam belt on it. It whistles most obviously from 2k which seems to be where it starts to run rich with the lambda factor being almost twice what's required.
    It's a good data set. It shows bnt running within 10mbar a lot of the time.
  19. m1keh Forum Member
    I'm not really following the running rich comments along with Lambda trims- unless you have a diffrent log showing lambda trims?
    A lot of the highlights you have made in the file you have put up are from short tip ins and outs. Or from gear changes. The boost and lambda control will never perfectly follow during these manouveres. The log from BNT is from a dyno run which gives the controllers more time to hold things stable as the engine speed is more controlled.
    I Fired up excel this morning - you do appear to have a fair bit more airflow vs BNT for the same boost when plotting one of your longer pulls vs engine speed. Note some of this could be due to air temps which we don't have logged - and also maf to maf variability on older cars also.
    However the offset is around 8g/s which is around 29kg/h of air which from experience could be a small boost leak as the whistle suggests.
    I'm wondering if it maybe in the PCV system.
    There are quite a few good comments around what fails in the pcv system on the 1.8t listed here under issue 1. Although the cheapest fix appears to be a pcv delete...
    http://r-techperformance.co.uk/customer-pre-booking-checks-1-8t-20v/
    Finite likes this.
  20. Finite
    Northamptonshire
    Thanks for the in depth analysis/explanation. I am a total novice with turbo cars. It has two consistent apparently common fault codes
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    The DV has been replaced.
