Results 1 to 10 of 10
Thread: mk3 squeaking noise turning right?
    Banned
    Sep 2004
    322
    Just bought a mk3vr not long ago. When I'm turning right a squeaking noise comes from what sounds like the front wheel area!?
    any ideas?
    think I'll need new shocks soon aswell as these make kind of a squeaking rubbing noise from the rears when going over bumps at low speeds!
    Craig.
    CGTI Committee - Club Secretary Crispy 8V's Avatar
    Oct 2003
    NW
    10,219
    114
    Loose/ worn Aux belt? that the one runs the power steering look for a shiney belt
    CGTI Member #4026 Mk 1 TDI, Mk 1 1.6 GTI, Mk 4
  3. #3
    Forum Junkie
    Oct 2003
    Antarctica
    1,343
    Alt belt or wheel bearing on its way out.
  4. #4
    Forum Junkie
    Oct 2004
    -51°29' 57”N-0°7’ 29”W
    18,736
    hmm, yeah, im gona go with the bearing. unless you'd describe the noise as more shreek?
  5. #5
    Forum Junkie
    Oct 2003
    South London
    2,413
    erm my blower motor bearing is going and when i turn right that squeaks.
    Turn the blowers off then turn right if i dont make the noise then its your blower motor.
    My name's Mark and I'm a Dubaholic
    2003 Seat Leon Cupra Sport
    1989 2 litre 16v Mk2 Golf GTi
  6. #6
    Forum Junkie
    Oct 2003
    Martorell
    1,783
    Put some insulation tape around your drivers door striker (on 'b' pillar where door catches) and see if it goes!
  7. #7
    Forum User
    Oct 2004
    Cambridge, UK
    71
    Have the same problem, thou the squeaking sounds like its comming from the passenger footwell, not the wheel. It could be the blower motor, but it still happens when i turn it off. Strange one? Getting p***** off driving with a mouse in the car!
    Mk2 8v, Look after her and she will be faithful...
  8. #8
    Forum User
    Jan 2005
    my girlfriend has a similar problem from her mk3.. sounds like the squeak that comes from the fan belt whenever she is on full lock... dunno what it is either??
  9. #9
    Forum User
    Nov 2003
    Wales
    365
    the squeek maybe the power steering belt.... changed mine before due to slipping and the squeek it made but now needs adjusting again =(
  10. #10
    Forum User
    Nov 2003
    Wales
    365
    o yeah keep it real my mk2 does the same, heater motor seems a litle stiff and squeeks now and again... got it from a scrappy after the other broke so no supprise its a little stiff 1
    Edited by: VeeDub_RS
