02a/j cable ends: improvement in design? work in progress
Discussion in 'Transmission' started by Jon Olds, Jun 14, 2020.
  1. Jon Olds Forum Junkie
    Been playing this morning doing a little turning. Pictures should tell the story.
    Never been happy with the end interface on the cables, so thought a rose bearing may be more suitable
    to get the articulation necessary.
    Could be an opportunity for someone to set up a CNC group buy type things.
    Simply bearings supply the rose bearing < £5
    Comments on my poor workmanship always laughed at. (I'm a leccy not a mechy...)
    Toyotec and Savagesam like this.
    its a good idea, you can actually get off the shelf kits from americaland but DIY is always going to be cheaper and more satisfying :)
    for my build I'll be using earlier type 02j ball joint type cable ends which attached to a modified 02a tower, using a polo 02j shifter. one day, when some of this mystical 'free time' becomes available that I hear people talk about :lol:
  3. pigbladder Forum Addict
    cambridge , uk
    does it need the ball /swivel? i got the american ones with a bronze bush in em , make a nice difference and seem to do the job well
  4. Jon Olds Forum Junkie
    I think, yes. The tower moves up down/left right, the swivel is achieved by the rubber mount. I knocked some
    nylon bushes up first with two tapers (concave looking in, both sides) but it was not a success. Just completed
    both this morning and happy with the result
    Jon
  5. Tristan
    Nice work John. Neater looking than the Dieselgeeks job.
    Does it feel much sharper?
  6. Jon Olds Forum Junkie
    Not got them on the car yet, will let you know
    Jon
    Tristan likes this.
  7. Toyotec
    I use that type on all 4 of my old classics.
    WOLF R, JENVEE, WOLF CC (MK1 20vT) and Project 8 (V6 24v MK2).
    The bush does make the gearbox have rod change like shift qualities IMO.
  8. Jon Olds Forum Junkie
    finished 'product'
    Jon
  9. Tristan
    Jon... Out of courtesy, I'd like to say to you, that I'd like to copy that design.
  10. Jon Olds Forum Junkie
    No probs. Rose joint ID 8mm OD 16mm, 22.5mm to inner step (just 'snaps' into plastic) , step about 6mm deep (1/2 width of plastic carrier),
    rest is obvious. Used 14mm end mill in tailstock to rough out bearing recess and bored out rest to 16. Used a ball end 14mm carbide
    to radius the inside to allow the rose to swivel.
    8BA nuts/bolts at 2.6mm clearance to clamp together
    Jon
  11. Tristan
    You're a gentleman.
