1.8t running stand-alone ecu, running issue
Discussion in '1.8 & 1.8T' started by 10mm socket, Jul 21, 2019.
  1. 10mm socket Paid Member Paid Member
    Hi guys.
    I’ve got ‘ten of the best’ this coming weekend, but I’ve got an issue after the rebuild. The problem is that if I rev quite high and release the throttle, the revs drop really low to about 200 and then cuts out. Seems to be more of a problem when the engine is hot.
    Thanks in advance
  2. 10mm socket Paid Member Paid Member
    Hey guys, would a crank sprocket that has a worn key, that’s gives 2-3mm of movement on the crank end, be enough to knock the timing out? If so, enough to make it sound like a bag of spanner’s and pops n bangs
  3. rubjonny
    if the crank sprocket actually moving about get it sorted asap, once bolt tightened it shouldnt move at all
