16v Camshaft bolts - single use?
Discussion in 'Mk2' started by Eddie Tuke, Jun 16, 2020.
  1. Eddie Tuke Forum Member
    ISome advice please?
    'm having my '87 16v engine refurbed and am about to reassemble.
    I'm changing the head bolts as they are single shot, and con-rod bolts as they take a lot and are 30-odd years old.
    Do i also need to change the camshaft bearing bolts when I reassemble?
    Any others its wise to replace?
    Thanks for any advice
  2. Jon Olds Forum Junkie
    Always re-use cam cap bearing studs/nuts, personally. Obviously a good visual inspection
    first
    Jon
    Cleanliness is everything in engine building, everything
    Eddie Tuke likes this.
  3. Eddie Tuke Forum Member
    Big end bolts proving tricky to source. Keep trying or re-use?
  4. Jon Olds Forum Junkie
    Personal preference, key item. I wouldn't want to lead anybody on this, but I have been known to re-use on my own engines.
    Again, IMHO
    Jon
  5. rubjonny
    VW still sell them, 048105425. £10+VAT each though... nut is 048105427
  6. Toyotec
    Camshaft bolts can be reused 100%.
  7. Jon Olds Forum Junkie
    That's not daft money (unusually...)
    Jon
  8. H8V
    h8v Forum Member
    ...or on autodoc.co.uk or buycarparts.co.uk and their many other associated websites you can get Febi Bilstein bolts for about £3.84 and nuts for about £1.20.
    Granted the postage is something like £8.45, but it's still a saving and you might find some other parts you need on the website!
    Bolts... https://www.autodoc.co.uk/car-parts/oem/048105425#
    nuts...https://www.autodoc.co.uk/spares-search?keyword=048105427+
    bolts...https://www.buycarparts.co.uk/search?keyword=048105425
    nuts...https://www.buycarparts.co.uk/oen/048105427
