2.0 GTTDI BKD not starting after fuel filter change
Discussion in 'Diesel' started by Danallkins, Jan 5, 2015.
  1. Danallkins
    Danallkins Forum Member
    Deal, Kent
    As above really. The wife's golf plus, 2.0 GTTDI BKD won't start after a fuel filter change.
    I've changed the filter before and had no problems. This time I started it, got a little way up the road and it cut out and now won't start.
    Because I think the filter wasn't full of fuel when I changed it I've now topped it up with diesel but it still won't start... Can anyone help?
    Thanks
    Dan
  2. benthejettaman Forum Member
    some where in the uk
    have you got vagcom if so you can prime the system using basic settings
  3. Danallkins
    Deal, Kent
    Yep did that. Nothing!??
  4. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    With our diesel galaxy I had to bump it down a BIG hill.
  5. fasteddie
    fasteddie Banned
    Did you replace this seal .......................you should have :thumbup:
    And if you removed fuel pipes have you put them back in the right place [:?:]
    Would not recommend bumping a diesel. [:|]
  6. Danallkins
    Deal, Kent
    Yep new seal on and the big green one. Didn't take any hoses off.
  7. Danallkins
    Deal, Kent
    Taken fuel hoses off and turned ignition on.... No fuel came out so I'm guessing it's the pump. (Should I hear it prime like the mk4 pumps?)
    Is there a fuel cut off switch anywhere I should check before getting a new pump?
    And is it back seats out to get to the sender in the Golf Plus (sliding seats)
  8. 1990
    Rochdale, Lancs
    I hate to bang on about a ford but the galaxy was exactly the same.
    I don't think the pump works like a Mk2 petrol one, it's a 2008 so could be the same technology as yours. If the big hill didn't work I would have bump started it while being towed.
  9. Danallkins
    Deal, Kent
    I can't see how that would work if the pump isn't pumping fuel
  10. Nige
    Nige Paid Member Paid Member
    Maybe the ECU sees the speed sensor and tries injecting fuel ? [:s] I really don`t know, just guessing.
  11. MUSHY 16V
    aberdeen
    Most have the pump on the engine if it gets air locked after changing the filter
    It's a pure pain to get going again
    As said bump or tow start it
  12. Danallkins
    Deal, Kent
    Is bumping a diesel ok?
  13. G-Man Forum Junkie
    By the petrol pump
    Just throwing this out there, when I used to change the fuel filter on my old Volvo S60 D5 I struggled to start it and thought I'd screwed something up as it wouldn't start after a few seconds of turning the key.
    I then read on a forum way to get the the Volvo D5 engine going again was to turn the key so you can hear the pump prime, then turn the engine over constantly for 30 seconds. If it hasn't started by then stop for a few seconds, then try for another 30 seconds.
    I firstly didn't like the sound of it, especially as 30 seconds seems forever when doing it. But eventually it did start and found I had to do this every time I changed the fuel filter on the Volvo.
    I would try that though as it won't take long and wish I just kept cranking the engine over rather than bailing after 5-10 seconds worth of cranking.
  14. Danallkins
    Deal, Kent
    The recovery guy tried turning it over and over to the point the battery started to drain.. I'm at a total loss where to go now and what to check next
  15. G-Man Forum Junkie
    By the petrol pump
    Was going to say is your battery in a good state? From memory does turning the key without cranking it prime the engine? If so, maybe turn the key to prime on and off a few times, then maybe jump start to car to give the engine enough juice to crank the engine?
    Guessing the glow plug lights go out too and you can hear the fuel pump prime?
  16. Danallkins
    Deal, Kent
    Yep sadly that's all been tried. Recovery guy had a jump pack on the car when he was cranking. All lights go out fine.
    When he tried a few squirts of easy start it didn't even splutter.
  17. MUSHY 16V
    aberdeen
    Not tried bump starting it ?
    Danallkins likes this.
  18. G-Man Forum Junkie
    By the petrol pump
  19. Danallkins
    Deal, Kent
    A bit hard to bump when it's on my drive that slopes to the house lol
    Fuse etc all good
  20. MUSHY 16V
    aberdeen
    Recovery guy not tow it for you
    Can guarantee it's air locked
    Mechanic at work did the same to a ford Mondeo
    Tried for hours to get it started
    Ended up towing it with the forklift to get it started
