2.0L 16V FSI Head Design
Discussion in 'FSI (inc. GTI 2.0T)' started by Brookster, Sep 17, 2010.
Tags:
  1. veenh386 New Member
    I will send more picture soon. Engine is running now and is very strong.
    make the hydraulic valve mechanic was very difficult
  2. RobT
    RobT Forum Junkie
    Cheshire
    Very intetested to hear your experiences
  3. brutalmk2-16v Forum Member
    Manchester
    x2
  4. idrivemyself New Member
    Washington, USA
    x3
  5. lewp91 Forum Member
    Hertfordshire, United Kingdom
    any more news on these heads guys? also pics are dead :(
  6. Brookster
    M1 J40
    Time to revive the thread
    I've got a 2.0L FSI Engine to pick up 06D EA113 block
    Options are to get a kit made up to fit my ABF bottom end
    Or
    Use the Complete BVY engine :thumbup:
    Spec will be 45mm throttle bodies
    Cat cams
    High compression custom pistons (final spec to be confirmed depending on what fuel i run)
  7. Tristan
    Is that a turbo engine? Ally or iron block if not?
  8. Brookster
    M1 J40
    NASP alloy block
  9. Tristan
    I really want one of those. What were they fitted to?
  10. Brookster
    M1 J40
    Passat
    Golf
    Eos
  11. notenoughtime
    Essex
    Thread revival! Any updates on any of this?
  12. Toyotec
    Yes. Significant.
    One of the tasks that goes on for the benefit of the members by some poor volunteer :o
  13. notenoughtime
    Essex
  14. HPR
    HPR Administrator Admin
    erreesse and Brookster like this.
  15. Brookster
    M1 J40
    bump this thread
    AS well as better flow from the head ,also a big weight saving from the engine
    Developments -FSI BVY Block weights 19.4kg ( 23kg lighter than a ABF ) :thumbup:
    this one has just been shipped out for a project ;)
    ABF Block weight -
  16. Brookster
    M1 J40
  17. TonyB Paid Member Paid Member
    Ammanford, Wales
    Interesting stuff. I've got a few FSi and TFSi block in the workshop, but no use for my classes - has to be std type! They have a nice girdle design. Throw away all the internal oil pump, go dry sump and bobs your uncle :)
    There were some questions though, as to whether the alloy block was strong/stiff enough for serious power. Depends on what your looking at of course, but I know Colin Satchell went for a diesel block in cast iron block for his hill climb car over the alloy block. Ok, he's 270 odd bhp I guess, but that's well within the capabilities of an FSi headed motor.
    Even the VW/Audi works cast Iron blocked motors ran girdles and stiffening plates.
    I know the F3 Fsi motor runs over 200bhp on an alloy block, so not that bad.
    Its not so much that the block will break I think, but that is will twist/bend, causing tightening etc. and reducing power or even running bearings.
    I've not heard of any failures, but VW must have got Cast Iron on the turbo for a reason.
  18. yaya786 New Member
    This thread just died ??
    Where are the updates lol
    Its nearly time to start my own build thread..;)
  19. Vdub_NL New Member
    Just found an newer topic regarding this stuff..
