2036cc ABF 83.5mm 16V MS1 V3 & Jenvey 45mm DTH 200bhp + Project
Discussion in '16-valve' started by Brookster, Feb 28, 2009.
  1. fthaimike Forum Addict
    [:s]
  2. Brookster
    M1 J40
    MK2 Driver's Hey !!
    They are from Pace but waiting for a price from Pro Alloy.
    The servo is on the opposite side on a MK1 :o its the drivers seat that on the wrong side :lol: :lol: :lol:
  3. Brookster
    M1 J40
    Well just got an E-mail from Integrated Engineering the pistons have been posted so should be here in a couple of days.
    Painted the block today ready for everything else to arrive.
    Going to get some new Heat Wrap for the old Supersprint 4-2-1
    Also need to get the MK1 booked in for a Pipewerx 2 1/2" System
    The existing exhaust is 2" Stainless System which will be going to a good home.
  4. DGT
    DGT Forum Member
    The Highlands
    good read this thread..good project.
    did you have to fabricate an extension to fit the supersprint mani to your system, if you did you wouldnt happen to have the dims would you?
    cheers
  5. RIP-MK3 Forum Addict
    sunbury on thames
    *dumb question alert*
    so to make it a 2.1 - all you have had to spend on is the 40+ vat and the pistons??
  6. Brookster
    M1 J40
    [:s]
    42 for the 83.5mm bore & Hone
    420 for the JE 83.5mm forged Pistons from Integrated engineering.
  7. Brookster
    M1 J40
    The Supersprint came with the flange but it required a 2" x 600m extention welded onto it to fit the existing 2" Stainless system.
  8. RIP-MK3 Forum Addict
    sunbury on thames
    didn't realise that was all there was too it (parts wise), and the 'small' outlay of the pistons lol
  9. Brookster
    M1 J40
    depends what final spec you want, but yes if you can do all the work yourself its a fraction of the price is costs to buy a complete bottom end that has been built.
    i've gone for a complete rebuild with H-Beam rods, Race Crank and all new Main & Big ends bearings all held together with ARP Studs everywhere.
  10. DGT
    DGT Forum Member
    The Highlands
    cheers Brookster.
  11. Brookster
    M1 J40
    Made some progress today while waiting for everything to arrive.
    Fitting the water pump and Alternator bracket and side engine mount from the old block.
    Also transvered the twin Oil cooler set - up, the Water cooled Oil Cooler and the sandwhich plate for the Mocal 12 row cooler which has build in Thermostat so keep everything at the correct temperature. Run this set- up for the last ten years and works very well.
    Requires a remote Oil filter set -up due to the limited space between the block and the front panel.
  12. Brookster
    M1 J40
    Eurospec Crank arrived today ! cheers Neal H
    Just waiting for the pistons to arrive
  13. drunkenalan Paid Member Paid Member
    Leicester
    technically its still a 2.0, it would have to be above 2050cc to be a 2.1
    a true 2.1 is 83.5mm bore with a 95.5mm crank giving 2092.
    my 8v will be 2042, 95.5mm crank with 82.5mm bore
  14. drunkenalan Paid Member Paid Member
    Leicester
    is this the crazy scirocco that has the trumpets sticking thro a hole in the bonnet? if so its awesome, i have seen it a couple of times
  15. drunkenalan Paid Member Paid Member
    Leicester
    sexy
  16. Brookster
    M1 J40
    Yes its Paul Bargates famous Rocco Original 16v Left hooker , with the trumpets thru the bonnet.
    The cranks is an amazing piece of engineering, can't wait to se the pistons, the ARP Mains studs are coming with them too.
    and Hopefully the 45mm DTH Jenvey's will be here in a few days too.
    forgot what the final displacement will be for the 83.5mm bore and 92.8mm stroke is it 2036cc ?
  17. sambo Paid Member Paid Member
    You are well on your way now Brooky![:D]
  18. Matt82
    Matt82 Forum Addict
    GTI Scene
    lovely collection of stuff. ive been itching to build up a spare engine for years
  19. Brookster
    M1 J40
    Cheers can't wait to get it finished an get back racing again.
    Hopefully should have the Microsquirt and the custom loom made up next week too, will see how it runs on its so fingers crossed.
    a friend has Megasquirt on his Duratec engine on 45 DTH Jenvey's with very good results.
  20. G60Dub
    G60Dub Forum Member
    Angus
    Dumb question ALERT - Er where does the oil filter go? [:$]
    Scrumptious crank! sigh... :thumbup:
