I'm finally getting around to sorting this out judging by the oil I thought I'd start with 6 Tried a new seal, but there is far too much play in the mickey mouse tinpot union. I'm going to try some self amalgamating tape on it tomorrow since large heat shrink seems not to be stocked in the UK. Are these pipes NLA now? I also have a seal, pintle, filters kit for the injectors, but am I likely to need seats as well and would that be more of a manifold off job? Cheers.
whats the car, year and engine code? its worth trying VW before the internet, I needed a lower intercooler boost hose for our bora and from VW it was cheaper than all the crappy used hoses on ebay
It's an 03 A3 8L AUM. I could see the part no. on it this morning it's definitely the so called upgrade part 06A145790C. I did find some UK stocked 76mm heat shrink so I'm going to give that a go first. Seems like the hose is pushed a bit too far onto the pancake and is under too much tension imo. Thought about making a support out of a 63mm exhaust bracket with some twisted strip steel off of one of the M10 holes on the back of the block, but cost wise probably not worth it as it would probably need a custom heat shield jacket.
06A145790C is available at 63+VAT, so yeah I would try to get what you have fixed up first if you can on the bora pipe I replaced it had the same clip type fitting but the nibs the clip locks over were all worn away so it kept popping off
sorry I missed your other question, usually the seats are fine but they are only 3+VAT from the dealer if you're worried 06b133555H
Cheers for the prices, no worries. The nibs are ok on my hose, but theres 1mm plus of play. The robust long term solution seems to be to cut the female socket off flare the pipe cut the male off and use a coupler plus short section of hose. I might get those seats as insurance against doing it twice.
Ordered one of these from Creations Motorsport for 45 Hopefully it will do the job the end is machined instead of pressed.
Will do. I'm fully expecting them to send the wrong colour hose even though I sent a message about it within a minute lol
Let us know how you progress with this. With 20vTs they tend to commonly loose boost via the recirc also. However as they get on with age, other places can also leak.
Fitted part of the hose today. The silicon hose was a non starter as it's not really to pattern and lacking flexibility so I had do what I was hoping to avoid and to cut the socket off of the OEM hose. It's a very simple process. One nick in the skirt with a hack saw and it literally tore & peeled off when twisted around an old pair of side cutters. It's put a bit of slack into the connection, but moved the hose closer to the block. Primarily I bought the package to avoid taking it apart to size the fitting which I believe is 64&54mm and £25 on it's own. Unfortunately the noise is still the same from 2000rpm which along with some traces of aluminium makes me think the noise might be the turbo itself. On the bright side it did pass its MOT earlier in the week.
Thanks, that will be a great help. I might take it somewhere to nail this down as I don't have the time now and want to get on with the Golf.
Right so I have my own vagcom setup now instead of borrowing. Logged these values this morning. Chopped to fit I've highlighted a few lines, but I've no idea what normal values are. I did also fit a new genuine DV to no avail. Thanks in advance. Group A:'003Group B:'115Group C:'031Idle speedAir mass inThrot AngleIgnit AngleEngine SpeedEngine LoadSpec. BoostActual BoostLambda FactorLambda FactorBin. BitsBin. BitsTIME700-820 rpm2.0-4.5 g/s0.2-4.0%0-12 BTDCTIME700-6800 RPM15-150%990-1800 mbar<=1800 mbarTIMEMARKERSTAMP /min g/s% °BTDCSTAMP /min% mbar mbarSTAMP117.17192029.1425.514.3116.361160159901000116.760.861 118.47144016.3112.215.8117.67200067.79901180118.071.0161 119.78224026.0616.921118.87168053.49901070119.280.9921 120.98304017.641130.8120.18252063.99901170120.581.0081 122.19184031.4772.914.3121.39284013.59901090121.791.0551 123.51252065.581006122.692120102.316301260123.090.9841 124.8332076.2891.415.8123.912760137.615601670124.310.9921 126.13404094.3610020.3125.23520122.614801460125.620.9921 127.334680109.9410018126.514240118.814801480126.930.9530.945 129.54352078.9210012127.844960120.314401460129.140.8050.899 130.85364014.78936129.953600119.514701460130.430.860.992 132.0535207.616.733131.25360020.39901060131.650.9451 133.3634006.755.938.3132.453480129901020132.961.0311 134.5632807.175.938.3133.76336011.39901020134.181.0161 135.9731206.815.937.5135.07320011.39901010135.570.9841 137.1823605.564.730.8136.37308011.39901010136.770.9841 138.38196014.7210.221137.58196051.19901010137.980.9921 139.6196011.78921138.78196038.39901040139.181.0081 140.9196011.94921140196032.39901020140.50.9921 142.11196014.6910.621141.29192033.19901020141.710.9921 143.41200037.4752.911.3142.51196045.99901020143.010.9381 144.62212050.611006143.822040102.316201280144.220.9691 145.93228034.9720.810.5145.122160130.816201550145.5211 147.34232035.4721.615.8146.43228057.99901200146.830.9141 148.64244063.831003.8147.842360100.815801260148.240.9061 149.85260062.331004.5149.052480134.615901630149.450.9530.945 151.05268065.441009150.252600129.315801600150.650.9380.945 152.37264012.113.90.8151.45272079.79901270151.871.0081 153.7725204.924.30152.76260012.89901030153.281.9911.047 154.9724405.835.10.8154.17248012.89901010154.571.9911.047 156.1923205.895.11.5155.39240012.89901010155.791.9911.047 157.522406.925.512.8156.59228012.89901010156.991.9910.797 158.8220024.9215.720.3158220049.69901000158.41.0161 160.1122007.087.122.5159.21220059.49901140159.610.9451 161.32212075.923.3160.51216022.69901030160.9111 162.62208010.728.221.8161.82212020.39901010162.220.9841 163.93204022.2515.720.3163.02204029.39901000163.440.9921 165.24208031.2819.613.5164.33204062.49901100164.8411 186.66184023.5815.717.3185.86160058.69901070186.260.9841 187.97220017.031122.5187.06200062.49901150187.4611 189.17232013.679.424188.37224035.39901050188.771.0081 190.3724006.694.324.8189.57236034.69901020189.970.9841 191.69164015.3310.618.8190.79208014.39901020191.291.0311 192.9172012.118.619.5192.09164046.69901020192.50.9771 194.2184021.0614.118193.4176046.69901020193.811 195.51200023.514.919.5194.61188060.29901100195.0111 196.82220026.4415.720.3196.02208060.99901140196.420.9921 198.02240033.5818.821.8197.22224063.99901170197.621.0081 199.24208010.5610.219.5198.42248066.99901280198.8411 200.44204029.6918.815199.64196065.410201070200.041.0231 202.45228028.5816.520.3200.84212074.410201250202.050.9841 203.86240026.4215.721202.95232061.79901210203.360.9921 205.06248018.9712.225.5204.26240052.69901130204.660.9771 206.28248015.7810.625.5205.47248041.49901070205.871.0081 207.48252014.4410.226.3206.68252035.39901040207.080.9841 208.79260052.3930.217.3207.88252032.39901030208.290.9771 210.1280035.832022.5209.192680101.513701410209.70.9691 211.324409.613.90.8210.5280037.69901150210.90.9381 212.7122002.033.52.3211.81188012.89901020212.311.9911.047 214.1121605.114.32.3213.22220012.89901010213.711.9911.047 215.4321206.115.126.3214.512160129901010214.930.8990.797 216.63212020.5613.322.5215.83216038.3990990216.221.0311 217.94216015.9410.622.5217.04216048.19901060217.540.9691 219.25220030.2519.220.3218.45216039.89901040218.851.0231 220.56228050.47609.8219.75220077.412301240220.1411 221.76240062.141003.8220.962320121.816001480221.360.9841 223.1724809.148.225.5222.162440133.112701520222.670.8831 224.3824809.757.525.5223.57248027.89901040223.970.931 225.6824404.283.932.3224.88244022.69901010225.281.0081 226.9923604.223.532.3226.082400129901010226.50.9611 228.1923605.114.332.3227.39236011.39901000227.791.0621 229.4123205.284.731.5228.612320129901000229.011.0391 230.7222405.814.71.5229.812280129901000230.211.0081 232.1322005.564.72.3231.21224012.89901010231.611.9911.047 233.4221205.474.72.3232.62216012.89901010233.021.9911.047 234.6420805.284.72.3233.82212012.89901010234.241.9911.047 244.8196030.9724.715.8243.98184030.89901000244.40.931 24620808.585.521.8245.2204072.99901220245.60.9451 247.2119603.893.92.3246.4212020.39901020246.810.9611 248.51164023.8920.415.8247.71160012.89901010248.110.9061 249.82180028.9219.614.3248.92168075.211501130249.4211 251.04192024.1414.117.3250.22184078.910801240250.620.9921 252.33204025.2515.718.8251.53196065.49901160251.930.9921 253.55220036.8121.615.8252.73212072.212301180253.151.0311 254.84176015.1111.417.3253.95224053.49901270254.441.1721 256.15192038.5899.69255.26184064.712101050255.751.0391 257.37204050.311006256.55196010915501340256.970.9921 258.67216018.428.614.3257.872080127.815301520258.2711 259.9821603.924.723.3259.08220024.89901120259.580.9531 261.19216013.479.422.5260.38216018.89901010260.780.9381 262.49224047.3193.313.5261.69220045.99901010262.091.0551 263.71236063.28986262.892280118.815901420263.310.9841 265240010.694.725.5264.11240066.29901270264.60.8911 266.3124005.584.727.8265.42240017.39901020265.910.9381 267.5323605.674.730266.71236016.59901010267.111.0311 268.8223606.615.530268.02236014.39901000268.421.0311 270.1423607.926.326.3269.242360159901000269.740.9921 271.3523209.567.123.3270.54236019.59901000270.941.0081 272.7623206.425.129.3271.752320159901010272.250.9921 274.0623209.067.124273.16232015.89901000273.561.0081 275.2723206.035.130274.45232021.19901010274.871.0081 276.5723205.474.731.5275.67232012.89901010276.170.9841 277.8823205.584.731.5276.98232012.89901010277.481.0081 303.4319205.194.33302.53204013.59901020303.031.9911.047 304.7418004.863.93.8303.83188013.59901020304.321.9911.047 306.0517204.223.53.8305.23176013.510001010305.631.9911.047 307.3515203.423.14.5306.45164012.89901010306.951.9911.047 308.6613203.142.75.3307.74148011.310001010308.161.9911.047 309.978802.1720309.06128011.310001010309.571.9910.797 311.1714803.943.14.5310.3792013.510001000310.770.8280.797 312.469202.6921.5311.57124013.510001000311.991.8031 313.6810402.6124.5312.88144014.310001000313.281.0081 314.99248044.0630.620.3314.1100015.810001000314.590.9771 316.21316021.255.90315.39280096.210301330315.791.0231 317.62220029.2517.318316.6126801210001090317.10.9451 318.8222407.756.323.3318.02228050.410001160318.410.9531 320.13228016.0610.223.3319.22224035.310001020319.730.9841 321.3322802.083.92.3320.53232036.110001040320.931.0081 322.6416004.473.118.8321.73184012.810001030322.141.0391 323.8416003.222.715.8323.0416001510001030323.441.0391 325.1515603.672.425.5324.25160013.510001010324.750.9451 326.3716003.922.725.5325.5515601210001000325.951.0391 327.7716005.063.523.3326.7716001210001000327.2611 329.07168021.7514.917.3328.17160021.110001000328.570.9381 330.29188022.8614.518.8329.49176065.410001100329.891.0081 331.49208047.9498.47.5330.68192067.711001160331.081.0081 332.8240018.7211.821.8331.892160125.616001480332.30.9921 334.11256067.7899.211.3333.2240065.411501120333.61.0231 335.4296073.3610012334.612720134.6157016303350.9921 336.72332081.4210013.5335.823040128.615101540336.220.9530.945 338.03368084.9210015.8337.233480126.314701490337.630.9380.945 339.34400090.1910018.8338.543800119.514701460338.940.9450.945 340.65428096.3110018339.84408011814601470340.240.9380.945 341.964520102.3910018341.054360119.514701480341.560.930.922 343.164760107.8910015342.364600119.514601470342.760.9140.906 344.385000111.0610020.3343.564840117.314301430343.960.8910.891 345.68472015.945.93.8344.865080115.814101410345.270.860.984 376.34244016.3311.815375.54244013.510001020375.941.9910.797 377.65240022.6913.723.3376.74240051.19901030377.161.0081 378.85240011.584.327378.05240043.69901090378.450.9611 380.1623205.224.31.5379.27236012.89901020379.671.0231 381.4822405.444.71.5380.68228013.59901010381.081.9911.047 382.6820005.314.32.3381.88220013.59901020382.281.9911.047 383.9921605.584.32.3383.081560129901010383.491.9910.797 385.219204.833.93384.39184014.39901000384.791.9911.047 386.421205.724.72.3385.6220013.599010103861.9911.047 387.620405.114.38.3386.8212013.59901010387.21.9911 388.92220051.781008.3388.02208037.61240980388.420.9771 390.13252065.251003.8389.332320130.816001530389.720.9840.961 391.54292071.510010.5390.632640133.815701610391.030.9450.945 392.74324080.5810011.3391.943040128.615101530392.340.9450.945 393.94356082.9210015393.143360128.614901490393.540.9380.945 395.15388090.4710018394.353680121.114701470394.750.9380.945 396.37420095.9710018395.554000119.514701470395.950.9380.945 397.674520103.0610018.8396.774320118.814701460397.170.930.93 398.884840107.1199.614.3398.08464011814501440398.460.9060.914 400.29508019.586.72.3399.394920116.514201440399.790.8990.891 401.7316010.114.71.5400.79448011.39901110401.191.9911.047 425.0220005.224.32.3424.13204013.59901010424.621.9911.047 426.3319605.174.33425.52200013.59901010425.931.9911.047 427.6418004.863.93.8426.83188013.59901010427.231.9911.047 428.8316403.783.54.5428.04172012.89901010428.441.9911.047 430.0610801.891.63.8429.24156011.39901010429.641.9911 431.3614803.563.10430.56144012.89901000430.960.7580.797 432.5710402.3620.8431.75108017.39901000432.171.5691 433.7713203.222.73432.97144012.89901000433.370.9611 435.08120010.258.216.5434.28124012.89901000434.681.1561 436.28136023.3676.910.5435.48124061.79901000435.880.9611 437.5152019.782.417.3436.68144089.514901140437.10.9691 438.715206.86225.5437.9156016.59901070438.30.9531 439.9114405.614.721439.11480129901010439.50.9141 441.21144015.1111.416.5440.41140028.69901000440.811.1561 442.52152011.97917.3441.63148045.99901030442.120.9771 443.74160017.1712.218442.92156041.49901020443.321.0081 444.94180013.259.818444.14164060.29901050444.540.9841 446.1418008.283.13.8445.34180018.89901080445.741.0391 447.35184012.1499.8446.55180012.89901010446.950.9381 448.55204042.9297.310.5447.75188054.99901010448.150.9921 449.86244067.531006.8448.952120115.816001380449.370.9841 451.18284070.4210010.5450.262560136.815801630450.781.0081 452.49312020.532.70.8451.583000125.614201500452.0711 453.78268069.7599.610.5452.98252051.914401010453.380.9061 455.1244014.473.50.8454.182760132.315501610454.60.8671 456.322407.253.51.5455.49224012.89901050455.891.9911.047 457.5122405.194.71.5456.71224012.89901020457.111.9911.047 458.8222005.224.72.3457.91220012.89901020458.311.9911.047 460.0221605.284.32.3459.212200129901020459.621.9911.047 461.3321205.084.72.3460.422160129901020460.931.9911.047 462.5321205.314.32.3461.73212012.89901010462.131.9911.047 463.8520804.894.313.5462.93212012.89901020463.351.9910.797 465.05212012.44922.5464.25208015.89901010464.640.751 466.3621204.334.327.8465.46212029.39901010465.960.9841 497.8419605.144.33497.04196012.89901010497.441.9911.047 499.1519605.144.33498.24196013.59901010498.751.9911.047 500.4519205.064.33499.55196013.59901010500.051.9911.047 501.6619205.174.33500.86192013.59901010501.261.9911.047 502.9819205.114.33502.06192013.59901010502.461.9911.047 504.2716404.533.94.5503.47188013.59901010503.871.9911.047 505.5813603.142.70.8504.69120010.59901010505.091.461.047 506.813203.332.70.8505.98156014.39901010506.380.930.797 508.0918805.194.33507.29164012.89901000507.691.1641 509.41208041.089814.3508.49184013.59901010508.910.8210.828 510.61284072.611009509.812280114.316101360510.210.9691 511.82364053.3321.621511.023160133.115101550511.420.9450.945 513.1324409.223.90.8512.22336010.59901160512.621.0471.047
Can you try to get a log from 1500-redline rpm at 100% pedal in third gear up a hill just to get a complete picture of the cars health? What exactly is your concern in terms of a noise? I'm assuming it sounds like a boost leak? This page is a handy guide for logging it is for tfsi's mainly but has some good pointers. http://www.goapr.co.uk/support/datalogging.php However I would replace group 31 in your original logs with group 114. But from your current data looking at time stamp 344.38 the airflow vs boost you are getting = 111g/s @ 5000rpm for 1430mbar boost. Which sounds reasonable for a stock 150hp 1.8t. I'd imagine at 6000rpm that will be up around the 120g/s region. So i'd say the log above suggests you don't have a boost leak unless it is quite a minor one...
The log for the car with reg "bnt" on the badger 5 site here provides a good reference data set. http://badger-5.com/bin/bin-index.php?dir=Dyno/asn-061110/
Thank you. Some of it was up a long hill run up in third. I'm a bit reluctant to red line it as it may well have the original cam belt on it. It whistles most obviously from 2k which seems to be where it starts to run rich with the lambda factor being almost twice what's required. It's a good data set. It shows bnt running within 10mbar a lot of the time.
I'm not really following the running rich comments along with Lambda trims- unless you have a diffrent log showing lambda trims? A lot of the highlights you have made in the file you have put up are from short tip ins and outs. Or from gear changes. The boost and lambda control will never perfectly follow during these manouveres. The log from BNT is from a dyno run which gives the controllers more time to hold things stable as the engine speed is more controlled. I Fired up excel this morning - you do appear to have a fair bit more airflow vs BNT for the same boost when plotting one of your longer pulls vs engine speed. Note some of this could be due to air temps which we don't have logged - and also maf to maf variability on older cars also. However the offset is around 8g/s which is around 29kg/h of air which from experience could be a small boost leak as the whistle suggests. I'm wondering if it maybe in the PCV system. There are quite a few good comments around what fails in the pcv system on the 1.8t listed here under issue 1. Although the cheapest fix appears to be a pcv delete... http://r-techperformance.co.uk/customer-pre-booking-checks-1-8t-20v/
Thanks for the in depth analysis/explanation. I am a total novice with turbo cars. It has two consistent apparently common fault codes 17545 - Fuel Trim: Bank 1 (Add): System too Rich 17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) The DV has been replaced.
