256mm rear brembo brakes on a mk2....
Discussion in 'Chassis' started by transitman, Aug 8, 2008.
  1. transitman Forum Member
    Hi all,
    I have the chance to fit Brembo rear brakes from a Leon Cupra R on to the rear of a mk2... however I dont want to change to 5 stud... what can I do?? What disks can I get that will have the correct offset and bearings in them that will be 256mm?
    Or what other ways can I get round it?
    Cheers
    Mark
  2. MUSHY 16V
    aberdeen
    the disk is the only stumbling block in this conversion
    if you can get 256 4x100 disk
    for the wheel bearing and stub axle see hear clik
    with this polo stub axle and hub the Leon Cupra R rear calipper carrier and calipper
    shoud bolt strait on
  3. MUSHY 16V
    aberdeen
    you coud re dril the five stud disks to 4x100
    not much meat will be left but it coud be done
  4. badger5
    nr Glos
    you know the rear brakes are not brembos yea?
    regular calipers on vented 256mm disks
  5. benthejettaman Forum Member
    some where in the uk
    by any chance is the off set on 256 disc the same as 16v 256 front discs
  6. MUSHY 16V
    aberdeen
    i was just thinking this
    the 4 stud polo disk from the wheel face to the other side of the disk
    is the same as a 8v disk and 16v 256 disk shoud be the same
  7. MUSHY 16V
    aberdeen
    Quote:
    Originally Posted by transitman
    Would this be the same if I wanted to fit 256mm rear disks to my car with the brembo calipers from a Leon Cupra R??
    As the disks from the cupra would be 256mm and 5 stud, could I not use some 256mm 16V disks from the front of the mk2 to fit to the rear, thus making it 4 stud??
    Cheers
    Mark
    i would say yes
    i have just tryed a rear polo disk on a front 16v hub and it fits
    do you have a Leon Cupra R rear disk
  8. MUSHY 16V
    aberdeen
    and if the 256 do fit why stop thar
    you coud fit 280 mm disks
    Eurospec do a 280 plane disk kit clik
  9. transitman Forum Member
    Ah I was led to believe that the rears were Brembos too... So If I got the calipers then for a 256 setup, could I not just use them with the standard mk2 disks or is the 256 calliper bigger than the standard mk2/3/4 rear?
  10. MUSHY 16V
    aberdeen
    no you could not use them with the mk2 disk as the Leon Cupra R rear caliper is wider
    to for 256 vented disk and the carrier is longer to
    the golf mk4 18t Anniversary has this set up to
  11. altern8 Forum Junkie
    Cocos (Keeling) Islands
    what about seat cupra r? they are 4x100
  12. MUSHY 16V
    aberdeen
    are thay vented
  13. MUSHY 16V
    aberdeen
    ok just spoted this the 16v 256 is 20mm thick and the seat Leon Cupra R rear disk 256 is 22 mm thick
    20 mm is the mim size for the Leon Cupra R disk
  14. Mook
    Mook Forum Member
    South Coast
    I just don't get the point in fitting such large disks on the back. The back brakes are hardly used and, for the money you'll end up spending, you'll not notice any significant difference.
    You could fit a manual brake bias valve, but you risk the back end locking up if you don't get it absolutely spot on.
  15. Peter Forum Member
    I googled MK2 256mm rear brakes and it brought me here,
    I have a 1990 MK2 CL 1.3 that i''m contemplating doing a 12v vr6 conversion on, id be looking to convert to widetrack at the same time with 5 stud wheels.
    I have a surplus 256mm x 22mm vented rear brake set up (discs, pads, carriers and calipers) off a MK4 4Motion,
    is it possible to use this setup on on the MK2?
    I'd be using 15" wheels so no BBK on the front and I'm slightly concerned about too much of a rear bias, (i'm guessing 288mm will be the biggest I can fit on the front)
    Thanks in advance
  16. rubjonny
  17. rubjonny
  18. Peter Forum Member
    Many thanks for the replies, looking at the thread it looks quite involved, the main motivation was cost as I have the brakes surplus , sounds like it would be more cost effective and straightforward to go for the smaller non vented option, thanks again.
    Coincidentally these popped up on instagram earlier using a larger disc but the calliper is the same
    https://www.instagram.com/p/B8ufrSfHoCS/?igshid=1q5gfzx30ub4i
  19. Jon Olds Forum Junkie
    Best conversion I have done recently is proper 4 pots onto a Pulsar 4wd turbo rally car
    Jon
  20. rubjonny
    yeah you'll have to buy more bits to use them so if cost was the reason cheaper to keep it standard. not like you actually need anythign bigger, even the stock ones need to be pretty much crippled by the bias valve to stop it over-braking at the back
