70mm drive by cable throttle body
Discussion in 'Turbocharged, Supercharged or Nitrous !' started by 10mm socket, Nov 30, 2016.
  1. 10mm socket Paid Member Paid Member
    Evening folks,
    Currently on the look out for the above item. It's for my big turbo build, I can find plenty of dbw TB's but struggling to find anything that's compatible with an Agu running emerald k6
    Thank you
    Better still, I should be asking is a 70mm adequate for a 550bhp big turbo, without nitrous?
    This is all new to me.
  2. notenoughtime
    Essex
    What's your spec to get 550? Would like to know :thumbup:
    What size is vr6 one? As that should be capable
  3. 10mm socket Paid Member Paid Member
    Carey, you nosey old git!
    guess who it is?
  4. 10mm socket Paid Member Paid Member
    65mm, apparently on vortex its recommended to use larger than 65mm over 450hp
  5. Tristan
    sparrow likes this.
  6. notenoughtime
    Essex
    I did wonder!!! :thumbup:
    Get some more details up, the guys on here will be interested and would like to help out :thumbup:
  7. mickey marrows Forum Member
    Isn't the 2.9 corrado throttle body 70mm?
  8. Toyotec
    VR6 engines that run a M3.8.1 ECU, use a 70mm VDO throttle, that is similar on operation to the M3.8.3AGU engine.
  9. 10mm socket Paid Member Paid Member
    Is that the obd1 throttle toyotec?
    Thanks
  10. notenoughtime
    Essex
    I have one of those!
  11. 10mm socket Paid Member Paid Member
  12. sparrow Paid Member Paid Member
    Leamington Spa
    I use a VR6 throttle body on my turbo build. Only 350bhp, but it's fine. I think that's 70mm?
    The K6 will be able to use it with no problem.
