looks liek it may have had scuttle done before and not well from the extent of the rot and the bad spray job
Exactly crap work done 8-9 years ago and it's then been in a garage for the last 7 slowly rotting But we've started to look at it so hopefully it's not to rotten underneath looks ok but ther is surface rust and under seal loose so need to do some stripping and treating brilliant job "not"
Pics of stuff I did last night for half an hour Scuttle looks shot so will take a look at donor car today or tomorrow to see what can be done
Hi mike, going to start calling you Noah! You've got two of everything in that yard of yours! Cheers, stew.
So on Monday after workI cut the roten scuttle out Monday at work I cut the good scuttle out of my c reg donor Today welded up right hand wiper hole and repaired a couple of rusty bits on it . Need to get some weld through primer ready for welding it on Probably should take the dash out
Hi mike, sounds like you are making a good start on this one. Don't suppose you've got the rain tray still available at all have you?
So here's a picture of the modified dizzy ?? Standard one Been told the mod is something to do with advance and retard
There is no advance and retard on that dizzy ...clean it up and paint it Red The thing to check would be to measure the width of the trigger windows to a standard one
Trigger windows appear to be the same 16 mm Just more gubbins in the bottom of the gti engineering one
piiiiicccssss also can you check the windows are in the exact same positions relative to the shaft as the std 16v and not moved about slightly
Jonny tell me thy wish and I wiil endevor to oblige my liege lol Got to go and load a lorry and fix a machine back later lol
Well I've got 4 dizzies on my desk lol In original pics post 133 first 2 pics are re2000 one and 3&4 are a standard part numbers are different is this just re2000 one old design ? Draw a pic of what you want me to do and I'll try
