I fitted this timing belt about 7000 miles ago to my scirocco thats running an ABF, I'm not really concerned as i know the belt still has many many miles left in it but im a bit curious as to what might cause this mark going down the middle of the belt? The car runs great with no strange noises from the belts and as far as i can remember i set the belt so i could only just about turn it 90 degrees by hand. Is it too tight? or is this mark nothing to be worried about? Thanks!
IIRC 90° cam belt twist is for 8v engines, 16v timing belt should not go past 45°.. do you have spring loaded tensioner (M8 nut) or old style tensioner (m10 nut) ?
Thank you both, I never thought about the tensioner groove, thats re-assuring to know! I'll recheck the belt and tensioner type, its definetly tighter than 90 degreees but probably looser than 45 Thanks
Checked this over today, i have M10 nut tensioner and the belt is actually closer to 45 degrees than 90 so all in all im happy with it. Thanks for the comments!
