AGU Block to Gearbox Cover Plate
Discussion in 'Transmission' started by Nightroamer, Mar 18, 2019.
  1. Nightroamer Forum Member
    Hi All,
    Anyone know where i can get the above new? does anyone remake these?
    I think it is item, 06a103645 (no proceeding letter)
    TPS say no longer available and mine is pretty mangled.
    So thin i cannot see many used ones being in good condition....
    Thanks
    when I put it into ETKA still shows as available and its reasonably up to date, 17.98+VAT. though it may be when you actually try to order it then it comes back as NLA I've had that in the past.
    used ones are usually fine just need a damn good clean
  3. Nightroamer Forum Member
    Thanks dude, just tried another branch and they said the same!!
    I will re asses mine then and see if I need a new one or just some fettling ;)
