Atlas grey mk2 abf kjetronic. Hello! My name is Ivn im a spanish volkswagen fan, i have been reading this forumon shadows for years, and now i think its time for presentation. This is my second atlas grey mk2, some years ago I had a pb swapped to an abf (digifant), but unfortunately I loosed it on an accident. Since that day i have missed it a lot, it was a great car with a lot of mods, which i had to sell in that moment But some years later looking on secondhand cars websites on my country I found and advertisement of a atlas grey kr very closed to my city, I called to the owner and next day i was seeing it! This was what I found: and the engine: Not on her best times I think it looks really bad, a lot of electrical faults, missed pieces etc.. but after haggle the price with the owner i bought it just arrived on garage! Lets work! kr out: and just get the new hearth, abf! bodywork! Engine compartment ready for the swap: repairing engine wiring loom: abf rebuild: new clutch: And ready with kjet injection and gearbox abf inside and first start up! [video]https://www.youtube.com/edit?o=U&video_id=emRG_lVvaMI[/video]
atlas grey mk2 abf kjetronic. more bodywork: bbs ra Inside: Adjusting kjetronic and ignition time: Injectors calibration: New key: Tires: Almost finished: The interior is provisional, im looking for a complete recaro interior. And thats all for now, i hope you enjoy it.
atlas grey mk2 abf kjetronic. its not finished but I started the protect on march of this year. I forget to say that, the engine has 1mm of squish abfcams, 11 degrees for ignition timing,pressure fuel is 5.5 and on the wur 3.3 I dont know if this is the corret set up for the engine, it smells to fuel a lot and I can see black smoke on the back. On the other hand i hoped it will be a little faster it goes like my old abf with digifant more or less.
Atlas grey mk2 abf kjetronic. Now she looks like that, I changed the old bbs ra for ronals: Inside de car: I have the center caps of the wheels but Im not sure if she looks better with or without them: With some friends:
Now Im looking for a exhaust system, but I dont know which one will be the best.... 4-2-1 manifold or 4-1.... and on the other hand 55mm, 60mm or 2.5 inches... and which brand? what do you think?
Atlas grey mk2 abf kjetronic. Hi all, some pictures from this weekend In Matilla 1/4 mille races: My best mark has been 15.2 sg without RT with these tires and without seats: A video vs a golf v gti dsg remapped. [video=youtube;qwPt-WddZtA]https://www.youtube.com/watch?v=qwPt-WddZtA[/video] Here a plot from an accelerometer app: 163 bhp and 143 lft I think I can get a bit more from the engine, I have bought an AFR gauge and a knock sensor light for adjusting property the kjetronic. Knock sense light is like this: And im thinking on upgrades for the engine a new gearbox (02s gxv) and maybe diesel crankshaft and machine pistons or 83.5 je pistons I don't know. On the other hand im using a exhaust system with the same size of stock one 55mm, i don't know if i need to change it for a bigger one or if it is enough. Cheers!
golf 2.0 16v new abf Hi all! Last weekend I have been in a circuit with my golf, and at the end of the track day my engine has started to burn oil and the power lost were very notable. When I rebuilt the engine I noticed that cylinders werent in their best (too much km). So i just get a new abf lump: The cylinders look very good! Im going to porte and to polish the head myself, some advice? I though to open the ports to the gaskets size but i have just noticed that the head and gasket size is the same! so know i have no idea about how to open the head and gaskets (admision and exhaust).
Hogging out the ports does very little on a stock ABF engine. Best left alone. Car looks pretty decent!
THanks! im thinking to made a 2042cc and with a diesel crank and in a future wilder cams, thats the reason why Im hinting to porting the head.
At the end I rebiuld new abf with stock parts, tdi crankshaft it saved on garage, maybe on future will be usefull for something. New upgrade was to change old 020 gearbox to a new 02j 6v gearbox, with vr6 clutch and cable acconator. For fit it on golf i used a 02a gearbox case. Here you have some pictures of the process: speed 02a ring fitted for using g60 speed cable: 02s internal into 02a case: A little bit mecanized work: looks it works... ready for fitting on car! I had problem with selector but know it is solved! Now i am changing the kjetornic, i had problem with fuelling on high rpm, engine run very lean even with wur mod, so i am going to fit a standalone ecu, i donĀ“t know if a megasquirt or an ecumaster. Even i have doubts on what kind of injection using if a secuential or no secuential injection, and if letting the stock dizzy or use a coil pack.... Ivan.
