Ball joint extenders (REVIEW)
Discussion in 'Track Prep & Tech' started by 3hirty8ight, May 8, 2007.
  1. Bodge Forum Member
    :thumbup: <<< this face says so many words lol
    Thanks to people that cleared that up for me. I understand now, there to improve the roll center which is what ive lost from going low.
    So if your feeling bump steer from bump toe in can't you just just lower it alittle bit more so it transfers to bump toe out, Guess that might then distroy the roll center you've just sorted out lol, but thought there might be a magic level where bump steer is sorted but doesn't affect roll center to much (just thinking out loud really)
    As for making a model up of it can't it be worked out on paper?
    Where is everyone buying these from? and they only for mk1s?
  2. Bodge Forum Member
    sorry one more lol
    I understand that the rear end isn't effected buy how low you go been a soild rear axal?
  3. HidRo Forum Member
    Portugal
    Can you please tell me who is selling or where can i get these:
  4. woza Forum Member
    Sheffield
    The track rod ends are from Compbrake but as Micky said you can get Aurara rod ends that fit (and are probably cheaper).
    The extenders came via a group buy from the states - Dave Stone at PMWLtd. If getting the extenders suggest you get them made slightly longer than the default 1.5 inches.
  5. mk1g60turbo Forum Member
    Another group buy could be on the pipe line, all depends. ;)
  6. Fenn Forum Member
    Cornwall
    Aurara m14 female rose jonts are cheeper than compbrake ends. my complete kit with all fixings, misalignment spacers and dust covers worked out about 75. and is defo worth doing compared to fliped standard track rod ends.
    my cars much better to drive, still a bit twitch on bumpy roads at speed but think thats mainly down to the amount of power i'm trying to put down and diff. it's not perfect but a vast improvment.
  7. mk21147 Forum Member
    I have just fitted my ball joint extenders, flipped my track rod ends using the aurora rose joints. Now the track rods are tight against the anti roll bar. Has anyone else had a problem like this? My car is a golf Rallye.
    Please help
    Richard
  8. drunkenalan Paid Member Paid Member
    Leicester
    keep me informed please
  9. Fray16v Forum Member
    Dundee,scotland
  10. vw_singh Events Team Paid Member
    Is your front anti roll bar upside down? Because the pic shown on this page is of a mk2 and shows plenty of clearance.
    Gurds
  11. mk21147 Forum Member
    I don't think so, but will double check. Is it possible to fit the anti roll bar upside down, I think the anti roll bar would end up under the wishbones? I think the mk2 pic is running wide track, would this make the difference?
    Thanks for the reply.
    Richard
  12. rubjonny
    yeah it is possible to fit the bar upside down. this is the best pic i have of how it should be fitted, any help?
  13. vw_singh Events Team Paid Member
    I have seen it upside down on a lowered mk2 and the standard tie rods were making contact with the ARB on bumps. So fully possible.
    Gurds
  14. mk21147 Forum Member
    Thanks for the pic, I will have a look tonight. It does look like I must have fitted it upside down. Can I get away with supporting the engine & just undoing the back four subframe bolts to swap the anti roll bar round?
    Thanks Richard
  15. rubjonny
    yep, its a fiddly job but it can be done
  16. Fray16v Forum Member
    Dundee,scotland
    if it cost 75 your just as well buying the compbrake items as they'r 75 anyway and that's off ebay
    http://cgi.ebay.co.uk/VW-Golf-MK2-3...CarParts_SM&hash=item20ad9f1f17#ht_1863wt_911
  17. MK1-Tron
    MK1-Tron Forum Member
    Staffordshire
  18. mk21147 Forum Member
    Anti roll bar swapped round (it was upside down). Everything now fits spot on, thanks for all the help.
    Richard
  19. steved Forum Member
    Has anyone used these ball joint extenders with larger dia discs eg 300mm +, I've found the rubber from the lower ball joint touches the disc [:s]
  20. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    surley the disc would hit the boot higher up the disc if it wasn't there?
    has the anything else been fitted at the same time?
    I can confirm, I've seemed to of eliminated Bumpsteer from my own vehicle with these fitted, not able to test it correctly with exact measurments (minutes of degrees) until late Sept
