Hi Folks Just bought these four wheels with new centre caps , came off the guys Mk1 Golf Gti . I’m running a Mk2 with 8v with 16v hubs and 256mm Tarox Vented Discs and just Ordered Gaz Gold with (400/225lb) springs Car is a track car with a new built motor being done as we speak . Will those wheels be ok offset wise on a Mk2 for track day use ?? What’s folks opinion ?? Taff
Hi Taff, yeah completely fine! I ran RA for a while on track, with 280 discs - cant remember if i needed a spacer or not..but you should be fine with 256
Hi Fella, Thanks for that , only problem being Toyo R888R in a 14 come in a 185 x 60 x 14 I'm wanting to keep the look of the Car as standard as possible , so that will help , just wondered if i might run out of rubber, so to speak. Spec when finished below. Jenvey Throttle Bodies, Emerald Ecu, and Coil Pack Bored out to 1.9 cc, Wossner Pistons, BV Head (TSR D Spec) Kent 300 Cam, Lightened and balanced all internals Polished Crank, New Bearings, Arp Bolts, Baffled Sump,(TSR) Oil Cooler- Mocal 16v Re-built Box (TSR) with New Quaife LSD Helix Organic Clutch Gaz Gold Shocks (400/225 lb) Comp brake Adj Top Mounts Powerflex Black Rear Top Mounts Eibach Anti roll bars front and back BBS RA 14 " Toyo R888R Caged and Sparco seats and harness. No Carpets or sound proofing. After set up on rolling road should see around 180-200 Bhp ish!!! And rev to 8000rpm …… Standard Bumpers - Silver Stripe as Car is Black .
Hi Taff, sorry I had read that wrong! I thought you these were 15" not 14's! I'd advise to go up to a 15". It wont be noticable visually and will give you much better tyre options! I dont think 256mm brakes will fit under 14's but I may be wrong.
