Brembo Brakes Mk2 Golf
Discussion in 'Badger5' started by RallyeVR6, Mar 2, 2010.
  1. RallyeVR6
    RallyeVR6 Forum Junkie
    Hi Bill,
    Been looking at switching to the Brembo brake set up for my Mk2 VR. I can hopefully get the calipers, brackets, bolts and pipes from a friend (he's maybe goign even bigger) , but will require new disks and Pads.
    Do you still sell these, and if so is there anything in particular you would suggest to use as it is heading towards more Track use but still with some road use.
    Prices and availability etc would be appriciated.
    TIA. :thumbup:
  2. StuMc
    50? 20` 47 N - 06? 57` 57 E
    I`d recommend Ferodo DS2500 pads, which Bill does. :thumbup:
  3. badger5
    nr Glos
    5 stud? or 4 stud?
  4. RallyeVR6
    Lol, i suppose it would help if I gave all the info required wouldn't it?
    Its on 4 stud.
  5. badger5
    nr Glos
    305x28's then same as ibiza r mk3
    plain disks 60 each
    grooved 85 each
    ds2500 pads 109
    brackets 75 each
    mounting bolts 5 each (4)
    braided hoses 47.50/pair
    motul RBF600 brake fluid 10.99/500ml bottles
    prices exc vat and carriage
    carriage is 9.50
    regards
    bill
  6. GVK
    Bill, ta for showing us the various brake set ups last night, I will need some in the near future :lol:
    Just a question of do I go for bigger wheels and have no worries about clearance, or stick to 15s for cheap tyres and use spacers on teh front, which I'm not overly happy about due to scrub radius changes.
    You said you had some TD pro race 15s that you couldn't use any more , would you sell them?
  7. thegave Forum Member
    London
    Hi Bill,
    Sorry to bump an old thread but can you price out a complete Brembo kit for a MK2 Golf running 4-stud?
    Basically looking for the same setup as fitted to Leon Cupra R but will need everything, eg calipers, carriers, brake hose (braided please), bolts, Ferodo DS2500 pads and grooved discs. The elliptical ones, if you do them in that size (323mm?).
    Thanks
  8. badger5
    nr Glos
    LCR ones will not be possible on a 4 stud golf.. 5x100 323x28 disks with totally the wrong offset
    305x28 setup with brembo gt junior calipers is 840+vat and needs 16" minimum wheel diameter and 38mm caliper clearance from wheels hub face to rear of wheel spoke
    eliptical can be added for 50 more.
    regards
    bill
  9. thegave Forum Member
    London
    Okay thanks.
  10. thegave Forum Member
    London
    Bill, is the 305 setup the one that was fitted to Ibiza Cupra's as standard? Looking for something as OE/direct fit as possible, part numbers would be greatly appreciated.
    Thanks
  11. badger5
    nr Glos
    essentially 305x28 setup is what the ibiza cupra-r came with yes..
    i dont have part numbers, as I make some of the parts up myself.
    (cheaper than oe, and better quality)
  12. thegave Forum Member
    London
    Hi Bill,
    Can I trouble you to help me with filling out this chart? It's for the Brembo GT Junior kit, I need to see if the wheels I have will clear.
    Thanks
  13. badger5
    nr Glos
    your dimension A will need to be <50mm to clear the 5x100 323x28 brembo gt junior kit, or >38mm if the 305x28, 4x100 kit
  14. thegave Forum Member
    London
    What can I say, Bill? Just gorgeous engineering.
    Thanks!
  15. pj_sibley
    pj_sibley Forum Member
    Bristol, UK
    Hi Bill,
    Sorry to bump this thread again....
    Can you still supply eliptically grooved 280x22mm Brembo discs for a late spec (1990) 4x100 Mk2 Gti? I'm now running Audi S2 (Girling 60) brake calipers and carriers and would like to refresh the discs from my existing 280mm items (I was previously running the G60 variant Girling 54 calipers over these).
    Also - what sort of pad options do I have other than OEM and EBC Yellowstuff with the Girling 60 calipers? Ferodo don't appear to do DS2500s in the correct fitment.
    Thanks!! :thumbup:
  16. badger5
    nr Glos
    disks I do and have in stock eliptically grooved in 280's
    I dont think ferodo cater for your caliper tho.. I have been asked this before and they said nope.. not one they do I'm afraid.
    regards
    bill
  17. pj_sibley
    Bristol, UK
    Thanks for the info Bill.
    Are the discs you have eliptically grooved the 4x100 Seat Ibiza Cupra items? Are they one or two piece? I'm intending to use on track, so am keen to get something fairly durable.
  18. badger5
    nr Glos
    the ones I mentioned are 280mm G60/ibiza cupra brembo disks I have had machined..
    2-piece I do yes.. different animals tho.. and very different price.
    Is it 2-piece you are after price of?
  19. pj_sibley
    Bristol, UK
    I assume we're talking significantly more then LOL!!
    I'm also looking at Brembo Max 280x22mm, available from various providers. How do these compare to the eliptically grooved items you supply?
  20. 99hjhm Forum Member
    Soilhull, UK
    Give us a price on the 2 peice 305mm discs then Bill.
    I emailed you before christmas over the grooved 305mm, got no reply?
