Broken nolt in engine block
Discussion in '8-valve' started by Gerbertoyd, Mar 15, 2020.
  1. Gerbertoyd New Member
    Hi there, thanks for taking the time to read this and cast your opinion. I have had a local mechanic take the cylinder head of my newly purchased mk2 1.6 driver. The head gasket had failed and was in rag order to be honest.
    On the right hand side of the engine block between the bore of cylinder 3 and 4 there appears to be a sheared off bolt in the block. It appears to be filthy so I think it was previously broken. What does it do and would it be worth investing in a tap and die or similar ( thinking of just drilling it out with smaller drill bits.
    Dont know how to upload photos currently
    hello there, got any pictures of this bolt?
  3. copeidge
    copeidge Forum Member
    If the "missing bolt" is on the cylinder head, does he mean its missing a cam cap?
    If so thats totally normal, if you google pictures of the cylinder head they are all the same
  4. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
    The only "bolts" in the block are the 10 head bolts - if it's one of them then your mechanic is to blame.
    There are two locating dowels - towards the front of the block - one on either side. Are you sure it's not one of these?
  5. Gerbertoyd New Member
    Hello all, only just seen this response and my mobile Mechanic had now returned. It appeared my block was crackeded aswell so that was replaced with a 1.8 block. My problem now is other than the mechanic I have a spark fuel getting to the carb, cranks but doesn't try to fire.
