8v cam timing, you can't adjust it for more power, it's fixed by the cam, you can only move the position in the revs of what you have. Because whatever you add to one, you automatically take away from the other.
If you mean the inlet to exhaust timing is fixed, I understand what you are getting at. Only a special grind would change the lobe centreline angle. (LCA)
