Hi, The front bumper skin on my 1990 big bumper mk2 GTI is coming away from the bumper iron underneath, particularly at one end. I have cobbled together a clamp for the moment but what is the best way to fix it properly? Also, the rear bumper is misaligned and sits slightly low against the bodywork (see picture) - can i adjust this by loosen the bolts and moving it around a little? Thanks
you can adjust the bumper a little from side to side and in and out, but to raise it up you would need to bend the bumper brackets or make up spacer plates
