Car stalling after its warm
Discussion in 'Mk1' started by 0337, Jul 11, 2019.
  1. 0337 Paid Member Paid Member
    Hi all, I have a mk1 vw golf GTI, 1991 cabriolet. I seem to be having a problem with it as once it is warmed up and fan kicks in the car starts to struggle and cut out as if no fuel is getting to the engine side. It could be something else but when I give it gas it revs up no problem but as soon as I release the accelerator, it stalls, but starts up straight away no problem but still want to stall when ever I come to a stop at lights or a give way. Anybody have any ideas why it is doing this and what I can do for it to stop it ding this all the time.Thanks in advance
  2. GVK
    GVK Forum Addict
    Could be something simple like idle too slow, air leak, throttle body gunked up or CO too lean.
  3. rubjonny
    rubjonny Administrator Admin
    have a read through this guide, ignore the fancy 16v stuff just check thru the kjet basics:
    https://clubgti.com/forums/index.ph...air-and-tune-your-mk2-corrado-1-8-16v.195423/
    can use the guide above for reference on the timing marks also, but for ignition timing this is set to 6 degrees BTDC with vacuum line to distributor disconnected and plugged. Can usually ad a bit more advance from there, 8 degrees is a good start point but it depends on engine health/tune how far you can go with it and what works best. CO is set while engine is hot and idling, about 1.5% maybe a bit more again depending on engine.
    as above before messign with any settings check all the basics, air leaks, ignition & fuel system system health etc
  4. 0337 Paid Member Paid Member
    I know the co2 is quite high about 6.55, as I did take it to an mot centre and it showed up on the emmission tester as they were busy they couldn't set it but told me to come back and they sort it out for me (also needed a 3mm long allen key, had a 4mm for my Y reg) did check for leaks etc but none present. Will get CO adjusted and will get back to you all. Thanks for all your help.
  5. 0337 Paid Member Paid Member
    Hi all, ok took it to the MOT centre and tried too adjust the Co2, but it would not go down to where it needs to be but stayed around 6 ish. Tried turning the allen key both ways it would drop to 6 then start to rise again. Any ideas why. Did check the exhaust for leaks there is a small leak just before the centre piece so need to seal it there first, but can I check for anything else whilst am there. Thanks
  6. GVK
    GVK Forum Addict
    Have you checked the throttle body? If it's gunked up where the throttle plate is it will have high CO
    Also did they remove the breather hose and plug it off when checking the CO?
  7. 0337 Paid Member Paid Member
    No they didn't remove any breathers, which breather should they have removed, and what is the best way to clean the throttle body, using carb cleaner?
  8. GVK
    GVK Forum Addict
    Ideally remove throttle body for cleaning, use carb cleaner or gun wash/thinners
    breather pipe that goes to the air box/metering unit.
