Hi, I am in the middle of abf conversion on my '88 CE1 1.6 carb mk2. I can't seem to find parts number or the part itself online anywhere. So the part is 'Digifant ECU relay'. On the relay location 1. Does anyone know if I even can use this relay? Any other way? Am I completely on the wrong path? Also, Does anyone have any experience on the immo signal emulators. Such as this: https://www.ebay.co.uk/itm/264721728717
relay slot 1 for the digifant ecu relay can be used by splicing on plug 'R' to your loom. its only there on digi cars so if you only have carb loom you dont have one. if you dont have a plug R add a relay holder above the fusebox and wire the ecu relay to that instead have a read: https://clubgti.com/forums/index.php?threads/ce1-abf-splicing-of-looms-help.249714/ seen a few people use those immo emulators work alright apparently
I have decided to go for the relay holder and the mk3/ce2 ecu relay (5pin) as it has pin for the ecu live reference feed. That way I can get it the way it was meant to be on the mk3. Thanks rubjonny!
