Clutch pedal click at top of release
Discussion in 'Transmission' started by EZ_Pete, Oct 13, 2014.
  1. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    Hello peeps. Referring to my '91 8v Mk2.
    Just in the last few days, not every time, but maybe 50% of times when I'm releasing the clutch pedal there's a pronounced click as it travels the last 5mm (guessed dimension).
    It sounds like it might be something worn and jumpy in the pedal box, but its too rainy to investigate right now. It has a non-self-adjusting cable if that makes any odds.
    Ring any bells with anyone?
    Ta. :)
  2. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    There are 2 plastic 'things' between the pedal bow and pedal. Could one of those be worn out?
  3. rubjonny
    yeah theres like an over-centre spring under there, maybe its gone out of alignment or the retaining clip come loose. does it definitly sound like its in the footwell area as when i first got my GTI it had 2 biting points thanks to a knackered clutch with a bad click between them :lol:
    On my old 1.6 I didnt even have the over-centre spring, I suspect it may only be needed for auto adjust clutch cables
  4. EZ_Pete
    Sounds very footwellish, almost feels/sounds like the pedal rubber is somehow clicking under the ball of my foot, but I'm not sure that's possible. I'll try some different footwear if I can't see anything in/around the pedal.
    Cheers fellas. :thumbup:
  5. EZ_Pete
    Haven't test driven yet to check, but I think this nearly completely undone nut was the problem:
  6. Richard Mk2
    London / Bucks
    :o
    I think I'll be checking mine tomorrow Pete, just incase !!
  7. EZ_Pete
    It's only the stop to set the resting pedal height, don't think it's critical. If it's loose it'll move about and make a noise though.
  8. rubjonny
    that shouldnt be there :lol:
    looks liek your plastic clutch stop peg fell off and the PO couldn't find one to replace it...
  9. EZ_Pete
    lol
    Oh.
    Is the right bit on here somewhere?
    Struggling to make sense of that pic.
  10. rubjonny
    its part 16a, im not sure about 16b either? may be early or part of cruise system perhaps i dont recognise it mine certainly hasnt got one and all the pics i can find just show that hole with some tape over it.
    cant find a decent one with pedal stop shown either! I dont have a dash undertray on mine right now so will try to get a pic. but tbh, you could just leave yours as is if it works ok why mess! VW heritage have them in stock though
    edit: best i can find, if you squint you can just about see it just above where your bolty thing is:
  11. EZ_Pete
    Thanks John. Think I'm just going to pop a Nyloc nut on there, or a drop of threadlock, for now, until I find a secondhand one of 171721232.
  12. rubjonny
  13. EZ_Pete
    Oh, available and only a quid! Might have to treat myself in that case. lol
    Cheers for the help. :thumbup:
  14. Sheldon New Member
