Coilovers: grease the threads!
Discussion in 'Chassis' started by A.N. Other, Jan 4, 2007.
  1. rallyeluke Forum Member
    4 miles from castle combe!
    try using dax hair wax or black and white hair wax (if you have ever tried getting either out of your hair, then you will know how hard wearing it its) just a thought.
  2. Dub20vt Forum Member
    Somerset
    Yea carcenagenic too... what about some good old px (used to protect inside old aircraft bays on sea kings, lynx etc).. that's what i intend to use got loads of it at work :)
  3. Blue MK2 Forum Member
    i use copper grease and sometimes cling film them.
    If you have lost your adjuster key. Get a ribbon oil filter wrench. This will allow you to adjust the height on even rusted threads! + it doesnt damage the coiliovers [:D]
  4. gtijon Forum Member
    England
    Anyone tried Dinitrol? Or that Korrosionshutzfett stuff? I'd think they'd both stay put pretty well.
  5. Jetta Forum Junkie
    white spray grease? dosent come off the trucks at work even with 300 bar pressure washin!
  6. Supercharged Forum Member
    Grease will start to hold dirt eventually so no good...
    Gaffa tape or Elephant tape on new ones, will keep them brand new underneath, just take off and re-wrap every year or so!
  7. rick the spud Forum Member
    Near Arundel, West Sussex
    use a bit of 'man mayo'! it doesn't come off anything, and a little goes a long way... [:D]
  8. danTbone Forum Member
    bristol
    just found the same problem on my sisters polo 16v . went to put new wheels on only to find the fk collovers have seized tryed to undo them and the bottem adjustable plate just broke and the one above had a crack . so make sure you greese them up well if you want to adjust them [:s]
  9. RIP-MK3 Forum Addict
    sunbury on thames
    seems a little bit obvious, but even if you just adjust them a little then put them back straight away say every 3 months whilst spraying some WD40 would stop them seizng as well as stuff mentioned wouldnt it?
    Nope - WD hasn't got the staying power
  11. PhatVR6 Forum Junkie
    get some chain wax, for motorbike chains.
  12. A.N. Other Banned after significant club disruption Dec 5th 2
    Yep, found some in Halfrauds (someone mentioned this somewhere).
    All still in there, tank taped up, so fingers crossed it's doing the job.
  13. altern8 Forum Junkie
    Cocos (Keeling) Islands
    whats the best sttuff to spray on
  14. madmonkey Forum Addict
    Nordwest
    I used spray on waxoil. Seemed to do the trick.:)
  15. Mr Pearl Grey Forum Member
    Probably not much help now, but my stainless FK coilovers adjust very easily even after two years! Trust me it's the way forward, don't need to mess about with any gunk then.:) :)
  16. pyrotechnix Forum Member
    sock
    havin recently smashed my new jetta :( i took the engine and suspension out to find a wicked set o coilovers all neatly wrapped up in a 'sock'... threaded zip ties at each end and industrial velcro. not sure what the material is tho, about 3mm thick and waterproof lining, no siezin probs i hope!! not sure what they are tho... will post pix
    andy
  17. David Number 2 Forum Member
    Solihull/Coventry
    i wish i red this 6 months ago
    lol.
  18. Gaz16v Forum Member
    would ptfe tape work?[:D]
  19. neil kaye Forum Junkie
    england
    guys all these answers,white grease,chain oil,clingfilm,gaffa tape etc im jut wondering now if i shoult bother buying a coilover kit,surely the idea of the kit is to be adjusable,this thread has realy put me off and thanks to it you guys have saved me alot of money,i no the other reason for coilovers is so you can fit bigger or wider wheels but im on 195/50/15 and the car handles like a dream with my spax 60mm lowering kit,the reason i wanted the coilovers is to just lift the back end up a little so it wont rub when i have passengers but after reading all that ill prob just get 400mm springs for the back
  20. RIP-MK3 Forum Addict
    sunbury on thames
    wasn't aware coilovers allow bigger wheels?....
    it wouldn't put me off them, you just need to be aware that they take a bit of looking after. spraying them with bike lube isn't the biggest chore in the world is it?
