coolant pipe cracked
Discussion in 'Mk2' started by Big Mac, Feb 28, 2019.
  1. Big Mac New Member
    Hi all my 1991 mk2 gti has a crack in the metal coolant pipe that bends its way around the the engine. Is there a easy way to get this pipe out as it bends down in between the oil filter bracket.
  2. GVK
    When I did one many years ago now I took the whole front end off (Bumper/front panel /radiator/fan. etc) to access the pipe.
  3. rubjonny
    can be done with everything left in, just takes a lot of wiggling. if its about due for an oil change then pop the oil filter off makes life a lot easier
  4. valvemiester
    Trowbridge
    I did one quite a few years ago on a PB in situ just took a lot of wiggling around
