Crank pulley options for kr with mk3 alternator
Discussion in '16-valve' started by Wygolf, Mar 25, 2020.
  1. Wygolf New Member
    In the process of building my carbed kr I’ve converted the alternator and bracket to the mk3 8v unit with the big tension spring, I have a mk3 water pump pulley to go with it but not sure which crank pulley to use. Would an abf one work and if so where will be the best place to find one? I’ve seen 1.8t ones used but a spacer needs to be made to get it to line up correctly.
    I know it’s been done many times but struggling to find the info, any help greatly appreciated!
    you need the abf crank pulley, or people have machined down the 8v one
  3. Wygolf New Member
    Thanks! Any idea of a part number for the abf one? Or where’s best to try find one?
    037105243B, ebay sometimes has them or hunt around classifieds sections etc :)
  5. Wygolf New Member
    Thanks mate, probably going to be a nightmare to find as it’s the last part I need for the engine! If anyone sees this and has one/ has any pointers of where they’ve seen one give me a shout!
