Cupracraigs MK2 GTI 20v
Discussion in 'Members Gallery' started by cupracraig, Mar 5, 2018.
  1. cupracraig
    South West
    i think the money will be made on the loom parts, ce2 fusebox coloured connectors sell for about a tenner each
  2. dodgy
    Blimey, I must have loads in the useful box in the shed, kerching!
  3. rubjonny
    well, thats what people put them on ebay for. whether they actually get that money... I have enough to go into retirement if thats what they're really worth :lol:
    daNpy, cupracraig and dodgy like this.
  4. cupracraig
    South West
    i'll write a list of items i have tomorrow for you guys
    I have a mk3 loom from a 2.0 for some reason, no good to anyone i don't think, so seems the logical step to sell the parts
  5. rubjonny
    a complete loom would be worth selling yes, plenty of mk2 guys still installing 2.0 8vs in their cars. but single connectors not worth all that much, there is a seller who has caddy plugs etc for sale at steep prices but he's been trying to sell them for ages...
    also worth moey to mk3 guys who are doing engine swaps can use a donor loom rather than hacking up the original, means they dont have to take the car off the road etc
  6. cupracraig
    South West
  7. rubjonny
    all the mk3 engines have the round plug, easy way to tell the 2.0 8v apart is look for 3 pin plugs near round plug. if theres 2x knock and one crank then its abf. if theres 1 knock and 1 crank its AGG/ADY. if theres just a knock sensor, its 2E.
    you can also check the driver side loom as well, if theres a maf plug over there near the lambda its 8v, if just a 2 pin inlet temp its abf (not to be confused with the mfa outside tmep 2 pin plug, that one is white/red and brown/white or the dimdip resistor yellow 2 pin plug)
  8. cupracraig
    South West
    parts to sell:
    Parcel shelf - has been repaired but has a slight bow in it
    box of assorted 2.5" intercooler pipes and silicon joiners
    mk2 spare wheel space saver
    FMIC - measurements to come
    MK2 GTI seat foams, bolsters, Headrests and bases (mechanisms, rails etc)
    8v GTI pedal box
    1.8t hard water pipe (new) the one that goes around the front of the engine (bugiad bsp20449 OEM ref 06A121065AK) for AJQ;APP;ARY;AUQ;AGU;AQA;ARZ;AUM
    191971615A
    192819415C - Scuttle - small repair but visually good
    05A119518 - 1.8t dipstick cover
    191825250A
    191121294
    192863734
    191863679 - GTI Badge, original and great condition
    Armored door lock things - SOLD
    Fifft - dark tinted indicators front and side - one side one has damage to the clip
    Qpeng downpipe for mk2 - 1.8t - Trimmed slightly at the end to mate it to the trackslag system i had
    G60 brakes complete set up bar discs _ Pads are included - Calipers refurbished and with stainless hardware - on ebay
    MK2 GTI rear stub axles
    AGU 1.8T Sump - fits all the other 1.8t engines - good with a few small scuffs
    02j hard clutch line - good
    16v calipers and carriers - bit of surface rust from sitting in the garage for some time - threads are good and so are the rubbers
    k03 based 1.8t silicone TIP in black - good condition
    RamAir cone air filter to suit 1.8t MAF
    K03 turbo - boosted fine when removed - some slight play on the turbine and micro crack on the hot side (mileage circa 105k) i would run it again but they are also really useful for trade in if you are looking for a new/refurbished turbo but can't take your turbo off until you have a new one
    Vibratechniks front engine mount - on ebay with bids already
    535971056 - fog light loom
    358611307A - brake res - clean and good
    brake servo backing plate and rubber - good
    533721303 - rubber bung
    1j0121619a - 1.8t water pipe plastic y thing
    ce2 fusebox clip - white
    mk2-18t sutbby mater cylinder aluminium spacer
    191853678A
    2 x mk2 gti radiator holder things - L shape with rubber bungs - clip into where the bonnet latch goes
    1 x 1 way valve for vaccum
    Haynes mk2 golf restoration manual - vgc
    mk2 GTI speedo cable vgc
    06A145756A intercooler pipe bracket
    mk4 gti heater matrix pipes
    06A103943 - 1.8t front engine cover mount / oil dip stick mount
    06A129567 - heat shield
    357199853A - 02j gearbox mount
    06A145894C - intercooler pipe
    191837402B - mk2 window winders complete with handles
    033199207 - 1.8t engine mount
    mk2 GTI boot carpet - vgc
  9. rubjonny
    interior loom is 88-89 ce1 loom (is late ce1 because it has 11 pin red headlight switch) has an alarm tapped into it (big black box) so probably has a fair bit of damage on the harness
  10. cupracraig
    South West
    Ok thanks, i'll go and check it.. fingers crossed its ABF and i can get a few more quid for it
  11. cupracraig
    South West
    yep the alarm is a pain, but i thought i might remove the alarm, repair it all and sell it as a complete unit - spent enough time repairing looms in my one to make a nice job of it and that probably adds some value
  12. rubjonny
    yeah was going to say its easy enough to repair the dash looms back to oe as you can get all the pins new, except for the cluster wiring since you cant get the pins for those any more only option is splice and solder
  13. cupracraig
    South West
    welllll.. i don't know what the buyer is doing but the car still has no MOT
  14. Savagesam
    Breaking it!? :O
  15. dodgy
    Just admiring it probably.
  16. cupracraig
    South West
    dream car giveaways had it, so i think they will probably be re-spraying the thing
  17. Savagesam
    Oh really!? Is it on their website yet?
  18. cupracraig
    South West
    No, not for a while I don't think.theres a blue tfsi on their site at the moment
  19. cupracraig
    South West
  20. dodgy
    cupracraig likes this.
