Door lock latch spring
Discussion in 'Styling, Trim and Bodywork' started by mrglee, Jul 13, 2022.
  1. mrglee Forum Member
    Drivers door lock latch is lose and keeps dropping so the door won't close have to pull the inside door release and lift it back up I assume there's a torsion spring in there that has broken are these available or known specifications?
  2. PhilRyder
    The whole latch is £6 from Heritage which is remarkably cheap.
  3. stephen stanyer Forum Member
    I had the same problem could not find just a spring Heritage sell a spring but not the correct one. I bought a replacement on ebay and swapped the lock mechanism very easy job.
  4. mrglee Forum Member
    Could only find latches for MK1 & 2 need mk 3
    Couldn't find one on eBay front right drivers door with central locking but could just Rob the spring out of a non central locking Or is the latch removable from the rest of the assembly?
  5. stephen stanyer Forum Member
    I am not familiar with the with the mk3 but cant see there would be a difference in the trigger return spring between central locking and the non central locking
