Emerald wiring help
Discussion in 'Throttle bodies & non-OEM ECUs' started by Paul 16v, Apr 2, 2017.
  1. rubjonny
    much better :)
  2. Paul 16v Forum Member
    Well it still won't fire [emoji19]
    Will have to wait until next week now as I'm away for the weekend now.
    Sent from my iPhone using Tapatalk
  3. notenoughtime
    Essex
    Is the green light coming on when you turn it over?
  4. Paul 16v Forum Member
    Yes mate
  5. Paul 16v Forum Member
    All up and running, cheers for your help guys, reason it wouldn't fire is I had the fuel pressure reg feeding the fuel rail instead of after the fuel rail controlling the pressure [emoji23]
    Started 1st with this re piped.
  6. Toyotec
    Super!
    Now get it mapped and booked into a few events!
    Curby, Inters etc!
  7. Paul 16v Forum Member
    It has a map on it currently from when it was fitted to the last car. Where would you suggest to get it checked and tweaked?
  8. Toyotec
    Fit an AEM AFR gauge and I can come around and train you to look after it.
    Then you can be your own expert [:D]
  9. Paul 16v Forum Member
    Send us a link for the guage. I need to get a boss welded into my exhaust 1st
  10. notenoughtime
    Essex
    Can't you do that?
  11. notenoughtime
    Essex
  12. Paul 16v Forum Member
  13. mr.brown
    mr.brown Paid Member Paid Member
    Sunny Surrey
  14. Paul 16v Forum Member
    Thanks for the link mate.
  15. notenoughtime
    Essex
  16. Paul 16v Forum Member
    I've got a welder but don't know how to use it [emoji23]
  17. Paul 16v Forum Member
    mr.brown likes this.
  18. Hotgolf
    Smelly Cornelly
    Paul, you're spoilt mate!
    I've just put an0 Emerald in my mk1 which has no std loom, and it's been a pita! But, when I crank the LED flashes so it's pretty much there. Just need fuel and a laptop enabled 'user' to get it running ;
  19. Paul 16v Forum Member
    The loom needed a lot of work to tidy it up, but seems to be working now [emoji106]
  20. Toyotec
    Chop Chop then :p
    So ready then?
