Engine removal
Discussion in '8-valve' started by mk2 nas, Dec 6, 2015.
  1. rubjonny
  2. mk2 nas Paid Member Paid Member
    Northamptonshire
    Hi, I seem to have a spare wire on my 82 cabby,it's a thin black wire that comes out of the light coloured loom
    Casing at front of block,
    It's the one with the two plugs, one plugs on to water flange, and the other plug goes to the"thing"with the two fuel
    Lines going to it.wur?
    This black wire has nothing on it(just the wire).
    Any ideas plz.
  3. rubjonny
    chase it back in case its a random colour repair spliced onto the original wire. if black/blue its the oil pressure switch, red/yellow would be for the dash temp.
    if the car has points ignition its the spade to starter motor pin 15a, which supplies the coil with full 12v when cranking for easier starting
  4. mk2 nas Paid Member Paid Member
    Northamptonshire
    It's an original wire not spliced coming out of the sheath it's not that long either but could have been
    Cut or broke in the past.its hasn't been added it's oe.
  5. rubjonny
    have another look, it might be black/blue but very dirty? its the only factory wire i can think of that would be with those wires you mention apart from the black wire to starter.
    if the wiring loom is from a later kjet then it would be the 5th injector power feed to the starter 15a, if you look at your 5th injector does it have a black wire or a red/black?
  6. mk2 nas Paid Member Paid Member
    Northamptonshire
    Ok I've checked it again in better daylight and I can confirm it is dark blue and possible black also.i think it had an extended
    Wire attached to it (that I found under the car.)i must have disturbed it doing my engine change.so I think as you say it
    Goes to oil pressure switch.problem solved:thumbup:
  7. mk2 nas Paid Member Paid Member
    Northamptonshire
    Hi I need a gasket for water flange on my 1600 cabby (82).
    I've tried heritage they out of stock, however ive found one on eBay that's listed for a t25 looks the same.
    Is it likely to be a part for other models.my flange is metal one centre hole40- 50mm approx and two bolt holes.
  8. rubjonny
    is it the flat base type then, rather than havign a groove for an oring? decent gasket paper will do if its flat, just need to make sure head and flange are both nice and flat.
    linky for the t25 part?
  9. mk2 nas Paid Member Paid Member
    Northamptonshire
    Made my own from gasket sheet done the trick.but thanks anyway.
    now a new issue this car just keeps throwing up more and more.the banjo fitting
    to my fuel pump is cracked and leaking fuel not sure how long it's been like it.
    ive looked into new line at 50quid(pump to accumulator).but if I knew what to look for for size I can buy
    just the banjo.seen plenty on eBay but not sure what I need.any ideas.thanks
  10. rubjonny
    mk2 nas likes this.
  11. mk2 nas Paid Member Paid Member
    Northamptonshire
    Ok thanks once again rj.build is going good eg engine is now in running/idling.i have bombarded you with questions
    But this forum has helped me loads.
    One more though I'm going to remove all gear linkage and replace all the worn parts ive seen two repair kits but differ
    A bit .one has the shifter plate assembly and the plate with rivets.
    The other kit dosnt seem to have the above but has more plastic inserts one of them being orange which isn't in the first
    Kit.now I don't what one to go for.gearstick is sloppy like stiring soup.
  12. Finite
    Northamptonshire
    If you can find Wheeler Dealers Season 1 Episode 5 the car is a Mk1 Golf GTI and one of the jobs is the shifter repair.
  13. mk2 nas Paid Member Paid Member
    Northamptonshire
    Yes I've seen that got it up on I pad the other day.it will give me a few tips.car is coming along fairly well now.im hoping
    To have my full paint job done in the next month.then a new hood.my 10 month plan is on course to be road ready for
    2nd April.i Won't take it out on the 1st and risk looking a fool when my driveshafts fall off or something daft.lol
  14. rubjonny
  15. Finite
    Northamptonshire
    My parents married on April Fools day and that turned out ok [xx(][8(][:o)]
    So you'll be ready for the first Earls Barton CC show (if it isn't delayed until the field dries out) :thumbup:
  16. mk2 nas Paid Member Paid Member
    Northamptonshire
    when is the first meet I'm guessing April will poss be the first month.but my wife has arranged a break to the
    Canaries so I'm not gonna make earls Barton for the first meet.which is a shame.
    But I'm looking forward to Stanford hall 1st may ive been told.like that one a lot one of my faves.
  17. mk2 nas Paid Member Paid Member
    Northamptonshire
    Great write up on the gear linkage change.
  18. Finite
    Northamptonshire
    It's the first Wednesday of the month so 6th of April if the field is dry.
    Ah right I didn't realise it's a VW Rally at Stanford Hall. Big show even has it's own website then http://www.stanfordhallvw.com/
    I might go to that then, but not if it clashes with Curborough I really want to sprint the car there this year.
  19. mk2 nas Paid Member Paid Member
    Northamptonshire
    Stanford hall is a great show been there for the last 3 years.go if you can its one of the best.my opinion.
    Earls Barton is the day I fly back in late flight:(
  20. Finite
    Northamptonshire
    That's a shame, but it might not take place anyway. Next Earls Barton would be Star Wars day.
