Hi all, recently replaced the seals/jets in my Weber carb and it’s started having an issue where it dies as soon as the clutch engages. Revs fine, reverses fine(?) but first kills it dead. Is there anything I can try? Jets are the right size, gaskets in the right place, don’t have any parts that didn’t go back on so I’m a bit lost. it did do this briefly a month or so ago right after the carb was done but me and a friend replaced the accelerator pump for a slightly more substantial one, adjusted the mix and speed and it seemed fine. I did have to adjust the idle speed down again after the first motorway run as it had jumped up to 1500 but it’s been a few hundred miles since then and I haven’t touched it.
