Fuel pump pressure/flow
Discussion in '16-valve' started by SilverStar124, Aug 9, 2012.
  1. SilverStar124 New Member
    What is fuel pressure and flow on Golf mk3 2.0 16v ABF?
    What is fuel pressure and flow on Golf mk2 1.8 8v Digifant
    Do both fuel pumps produce same pressure and flow?
    Thnx
    rubjonny Administrator Admin
    digifant 8v MK2, early Toledo ABF - 3bar, 75 l/hr
    MK3 8v/16v gti, post-96 VR6 - 3bar, 80l/hr
    MK3 pre-96 VR6 - 4bar, 80l/hr
  3. Josh Gateh New Member
    Hi rubjonny, would you know if a 1.8 8v digifant fuel pump is up to the task to run a 1.8t conversion? I intend to do a swap to a AUQ engine with ECU tune so possibly looking at ~240 BHP
    you might be pushing it a little bit at around 240bhp region I recon, but speak to whoever is doing the tuning work they'll have more idea what sort of fuelling they want to see to support their recommended mods
  5. bonus85 Forum Member
    Soufamp'on
    While you're there - whats the spec for post 96 VR6??
    it does say in the post, same as GTI 8v and 16v ;)
  7. Josh Gateh New Member
    Cheers rubjonny. I'm currently focused on gathering parts so I guess I'll require an upgrade. I have an AUM mk4 golf unit around and can get a mk2 16v gti one as well
