Fuel Pump Whining - Part No - Lift pump & Main pump - PB digifant engine
Discussion in '8-valve' started by blu-tak, May 5, 2021.
  1. blu-tak Forum Member
    Hi,
    When cold my car (mk2 gti 8v 1990 Pb) is fine, nice normal initial fuel pump buzz on ignition, then pause before car turns over.
    However after a few miles, the rear driver wheel area is making a much louder whine / buzz / whistle / noise than normal.
    After some reading on this forum:
    mad buzzing noise from fuel pump | Club GTI
    High pressure fuel pump buzzing loud ?? 8v digifant | Club GTI
    noisy fuel pump | Club GTI
    I think my lift pump needs replacing - at least first. However I just can't work Etka out on this one.
    See below snips - they only show it for KR engine. or KJet engine.
    But I have no idea what illustration 216-10 is
  3. blu-tak Forum Member
    Thanks,
    Is it good practice to replace any other bits - like the strainer?
  4. Tristan
    I'd just clean it.
    After that, just the external filter, and hoses if required
  5. NateS2
    Yeah I'd probably throw an external filter on there first for what its worth, if its really clogged it could do that and its a lot cheaper than a pump. Could also try, if it makes the noise while parked, just unplugging the lift pump while the engine is running, just to isolate that it is that.
    You'll also want a new tank seal if you do swap the pump most likely - 6N0919133. Get it from the dealer, you'll be pleasantly surprised how much cheaper it is than from VW heritage. My old one has turned to basically glue after 30 years
    blu-tak likes this.
    try to get a pump which comes with a strainer, usually they do. theres 2 sizes so dont want to get caught out. I find the lift pump seal is usually alright but may as well get one if can find cheap
  7. blu-tak Forum Member
    Thanks, I did the fuel filter about 50 miles ago so I know that's good.
    Good tip on unplugging the lift pump.
  8. blu-tak Forum Member
    Yes thanks, I just wish I had better etka skills to work it out. I like to research stuff before I do a job you see.
  9. NateS2
    I must have gotten unlucky, had to wash mine off with petrol, was more like the texture of bitumen rather than rubber
  10. blu-tak Forum Member
    I found time to get the lift pump out.
    Here is a bit of a photo dump which I hope you guys find interesting.
    Petrol keeps things clean
    Split rubber
    Nice VDO guage
    Not sure how I undo this clip and save it - I think it's time I own some decent stainless hose clamps:
    Looks like original 1990 part
  11. rubjonny
    Thinking about it now, the last time I did one was 10 years ago :lol:
  12. blu-tak Forum Member
    Do you know part no?
    Etka and part itself don't say
  13. rubjonny
    which bit you after?
  14. blu-tak Forum Member
    You see the big rubber seal at top - that has split in the pics no4
  15. rubjonny
    Nate mentioned it earlier, 6N0919133. this one was superceeded by 191919133 then 4B0919133. Still available from VW or £10+VAT :)
    NateS2 likes this.
  16. rubjonny
    think etka has confused itself, since the original data history part is also shown as 191919133 :lol:
  17. blu-tak Forum Member
    and I in turn.
    Thanks to Nate as well.
  18. blu-tak Forum Member
  19. rubjonny
    Yes VDO made the later 19mm :)
  20. blu-tak Forum Member
    Is that good or bad? or doesn't matter?
