I just pulled the fuel sender from an 87 GTI 16v, part number 191 919 051 E. The in tank pump was connected to the assembly with a short stub of hose that has disintegrated. Now, I’m looking to get this back together but I feel I’m missing something...how do I get the pump to connect to the fuel sender assembly? It appears that a piece of hose can slide into the female part of the assembly and then other end clamp to pump...but how do I secure the hose to the female part of the assembly? I’m at a loss here...found several other photos of newer assemblies and few of the 3 pin type E...and all the photos of type E are missing the pump and the connection to it. Any help would be greatly appreciated...pictures, descriptions, etc. All I can think to do is use some fuel resistant RTV sealant to secure a small stub of hose to bottom assembly and the clamp to pump...but fuel resistant in a fuel bath doesn’t seem like a good option.
the stubby hose is also a reducer thats the trouble, part number 357919133 then its secured with a couple hose clamps N 10098001 and n 10083401/N 10196901. the 2 clamps are available but the hose is NLA but might be able to get away with normal fusel hose slightly undersize one end and oversize the other
