G28 Speed sensor + Japanese wiring
Discussion in 'Electrical' started by Louward, May 23, 2018.
  1. Louward New Member
    Hi totally new to this forum but I've been lurking around when I needed some info (and the info on here is really amazing - thank you!)
    So, car is a mk3 16v. Bought (second hand) in Japan, driven in Japan, mothballed in Japan.
    It needed so many fixes that I had to take it off the road. Finally getting back to starting it up again.
    The problem: The speed sensor (G28) broke almost as soon as I bought the car. Knowing nothing about cars back then, I took it to the local garage who couldn't fix it (subaru only) so he sent it to the local VW dealer.
    They said it was impossible to get a new speed sensor and so they made a temporary fix (which was electrical tape and soldering). It failed a couple of months later.
    Now I managed to get a new speed sensor from the UK, fitted it but I don't know which wires go to which pin..
    white, black, white/blue which one goes to 1, 2 ,3 on the sensor plug?
    pic
    Can anyone offer some advice? Is there any way to test this with a multimeter?
    Thanks in advance!
  2. GVK
    Louward likes this.
  3. Spacecowboy Paid Member Paid Member
    West Mids
    Should be able to use a multimeter to work out which is live which is earth and the remainder would be pulse. I've always known pulse to be the middle pin.
    Louward likes this.
  4. Toyotec
    Colours do not matter.
    Pins are 100%
    Louward likes this.
  5. Toyotec
    As I started all the ABF this and that on here, I thought it was fitting to have the ABF current flow diagram is on this forum.
    It is found >>here<<
    Picture repair to follow shortly.
  6. Louward New Member
    Wow, wonderful thanks GVK, Spacecowboy, Toyotec for the rapid replies and info!
    Just to clarify, and I've got to ask the question, the numbers 1 2 3 are in a different order on the wiring diagram (3, 1 ,2) - does that mean that the Hall supply is ALWAYS no 1 or ALWAYS the middle pin?
    Also, I just tested the wires with a multimeter and got two wires reading 10v. How can I tell the difference?
  7. Toyotec
    Hall supply is always 1.
  8. Louward New Member
    Thank you! I'll figure it out, cheers
  9. duremars New Member
    Does anyone know if this pinout is suitable for mk4 16v? I recently bought a golf mk4 but have never owned a German car before. I mainly used cars of Japanese origin. At the moment I use this car https://www.jdmbuysell.com/product/nissan-skyline-gtr-r33-n-8356/ as my main one and to be honest, these two cars are very different. I bought a golf for my wife as she needs a small, economical and fast car for the city, so I thought it would be a great choice. Since we bought a used car, it is obvious that it has some problems. I fixed all the body related issues, but I had problems with the electronics. I hope you can help me. Thanks in advance!
