Garage lighting (no mains)
Discussion in 'Garages, workshops & DIY' started by Ben S, Jul 31, 2008.
  1. TheSecondComing Forum Addict
    Quiet enough not to bother you if you stick it round the corner from the garage.
    Put it this way, I have one I use as a spare for TSC island, and from inside the house I can't hear it at all. The house is built from hardboard and pine cladding, and has holes in it big enough for a wild pig to climb through. Wolf brand, I think it is, but they are relabelled and sold by everyone including B&Q. 600w constant, rated at 720 peak but will pull about 900w peak and 850 constant if you need.
    http://cgi.ebay.co.uk/WOLF-PORTABLE...hash=item220262715851&_trksid=p3286.m14.l1318
  2. Admin Guest
    could you run a car battery and a light?
    then when you are done, take battery home to charge?
    my garage is just a little to far from home to run a power lead to it and is dark come the evenings now.
  3. Claypole Forum Junkie
    I'd be very tempted to tack a massive extension cable to the outside wall - you can get a 50 metre one from Screwfix. :lol: 29.99 plus 1.09 for a box of cable clips. ;)
  4. Admin Guest
    power drop?:lol:
  5. Claypole Forum Junkie
    They sell them so they must work, Kitemarked, Arctic cable etc. :thumbup:
    I've a 20 metre one I use with the grinder, sabresaw etc. all the time. :)
  6. POL
    pol Forum Member
    Scotland
    solar light and cordless power tools. charge them up overnight and get a spare battery. alt option is a geny but they can attract attention due to the noise.
  7. ev nutter Forum Member
    BLACKBURN, ENGLAND
    You ll have to get a pedal on to charge your battery bit tiring thou
  8. AndrewF Forum Addict
    Milton Keynes
    What did you go with in the end?
  9. Admin Guest
    indeed, what was the verdict?
  10. Brookster
    M1 J40
    i've got loads of Artic cable
    send my 15 and i'll make a lead up for you if your still looking!
  11. Admin Guest
    what is this artic cable?
  12. jamez Forum Member
    Netherlands
    I have the same situation , i have a 12v 225ah gel battery from a bus connected to a 1000 watt inverter to supply a 220vac 2x36 watt TL fitting, will run the light for about 8 hrs before recharge, i also run a grinder from it when needed. I could get more duration from the battery but the inverter shuts the power off when the battery level drops below a fixed level so you don't get stranded if its fitted in a car , down side is the battery weights 48kg
    Stumbled over a recomendation for this in an LED lamp test I ripped out of Practical Classics earlier.
    Unsure if the model is current tho.
  14. dan_1987
    dan_1987 Forum Member
  15. Mike_H Forum Addict
    I've got a mixture of LED rechargeable lights and an old fashioned 12v lead light, that runs off a spare battery. You can get by with that if you need to.
    I've also got a few Ryobi One+ battery tools, so if I need to do a bit of drilling or grinding on the car, I can.
    I bought a few LED lights from LIDL - the little round stick-on ones that take 3 AAA batteries each. You can wire 3 of them in series, to a car battery, and run off that for ages.
  16. Admin Guest
  17. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Thats what I would do. The cable could also save your life if there was a fire.
  18. mattneck Forum Member
    Mine does.. and its tempting to put it to use.. is it worth the trouble? :lol:
  19. 2dubnick Forum Junkie
    Worcester
    i tried loads off different things, mainly LED type rechargable lights, ended up with a 2.2kva generator, so much better but as said it attracts attention.
