Hello I have a golf mk1 cab from 93, i upgrade front brakes to 280mm, calibers from golf mk3 GTI. And Master cylinder from golf mk2. But brake pedal is still soft and has to Press pedal more. Will it help to make a rear brakes til disc conversion and change the break Lines to stainless.
sounds like you have air in the system, have you tried a pressure bleed? Also the rear drums might need adjusting slightly. You dont need rear discs for a good pedal, but you could fit some if you want
I have used pressure bleeding, no air. But i know my right wheel at back, is leeking a little bit. But Will it be a Big difference When mounting a disc at rear. Vs drums
Soooo, i decided to not change the rear drums brakes, i changed the rear brakes to all new. And iam waitung for mine steinless hoses. It feels real Nice the brake pedal and brakes Very fine.
