Golf mk2 2.0 20v itb
Discussion in 'Members Gallery' started by MasterMike, Jun 11, 2016.
  1. MasterMike New Member
    Hellevoetsluis The Netherlands
    Just a little oem+ upgrade that fits the theme of my car
    HPR, Toyotec and Spuugemmer like this.
    Another lovely touch.
  3. yaya786 New Member
    Awesome build Mike
    Do you know the duration & lift of these cams?
    I'm in South Africa we use a similar engine in the polo cup kit car but milder cams and much lower compression.
    The polo cup cam:
    295 deg & 9,6mm lift on the intake
    293 deg & 11,25mm on the exhaust side
    The cams you're using might be the G4H camshaft:
    310 deg and 12,5mm lift intake
    285 deg and 12,75mm lift exhaust
    Sadly mine for stolen and it's hard to find G4H rally cams in S.A.
    Also which injectors are you using?
    I'm maxxed out using 440cc injectors on 50/50 pump fuel and E95 ethanol mix making 161kw and 239nm
    The new plan is to use much larger injectors, more timing and full E95 ethanol(no mix) & hoping I reach the 170kw mark.
    Compression is just under 12:1
    I assume it's around 11:8:1
  4. MasterMike New Member
    I know that catcams in belgium makes the replica G4K (Golf 4 Kitcar) cams.
    Just contact them.
    I don't know what injector is used, but I can ask my tuner.
    If you use 50mm itb's, G4K cams and a nicely ported head you should do more than 170kw
  5. MasterMike New Member
    Finally up and running
    copeidge, afbiker02, HPR and 2 others like this.
