Hello! I’m new here and this my first post. First of all, I got a Golf mk2 two years ago and since that when i’m using my high beams, i’ve noticed that there isn’t ant blue light working in the gauge cluster. I have changed the whole cluster when i upgraded to tachometre, but still the blue led doesn’t work. Why is it so?
the main beam light is fed from one of the main beam fuses, so if you're sure both fuses are ok and main beam headlight wirign is all good (i.e. not spliced to one side, or replaced with relay kit) then you may find your bulb has popped. its a standard 12v bulb with a blue cap on it, rather than an led like the other warning lights. what fusebox is it, ce1 or ce2?
