GT30 build onto mk3 ibiza cupra
Discussion in 'Badger5' started by badger5, Dec 9, 2010.
  1. badger5
    nr Glos
    Some pictures of a work in progress Ibiza Cupra of Seans, in for GT30 turbo, external mvs tial, etc etc and mapping to suit.
    Manifold is Badger5 manifold tailored to suit ibiza fitment and clearance of coolant pipes out of bulkhead.
    Essentially the same spec as the mk2 golf is having done, but compact compressor housing used on this one as there is'nt room otherwise..
    some downpipe and external gate pictures of its tacked together stage.
    enjoy
    loving the tightness of your 'package' there
  3. badger5
    nr Glos
    its snug - lol
  4. sambo Paid Member Paid Member
    Very nice work Bill,
    i like where dump pipe is joining main exhaust, i think its way better then going into downpipe just after turbo causing turbulence and affecting gas flow at high revs
    You dont think merging it at more of a sharp angle would of helped gas flow further?
    I am having a go at making a manifold , downpipe and exhaust next week for a top mount GT3082R, i will pay close attention to angles W.G. tube exits collector and may make a full run for it seperate from main exhaust to maximise the flow as much as poss
    Out of interest what size is screemer pipe 1.5" or 2"?
    My manifold parts are ready :)
  5. badger5
    nr Glos
    I think for the flow which will be coming out of the wastegate vs the 3" bore which is some 4 feet away downstream from turbine, flow joining flow wont effect anything...
    38mm OD stainless tube on the external gate on mine
    make sure you back purge the fittings when doing the root welds.. TIG I presume?
    good luck with it..
    there's something very satisfying with welding tube into nice sweeps and bends.. sad git that I am
  6. sambo Paid Member Paid Member
    Nothing sad about it i say, must be very satisfying:thumbup:
    I have no Tig welder so i will leave it to pros when it comes to welding, it will be back purged tho, my mate is doing it
    I am gona construct it tho and well looking forward to it:)
    I will use 47mm ID tube for W.G. exhaust for max flow, Cheers Bill keep up the great work
  7. badger5
    nr Glos
    what size gate you running Sam? Mine on these builds are using the compact MVS Tial which is 38mm
    my ibiza runs the bulkier 44mm tial
    good luck with it.. you will deffo see some power gains from this.
  8. sambo Paid Member Paid Member
    44mm new Tail gate, water cooled option, slightly more compact design to but flows better then the old item
    I need a good flowing gate as i will be running fair bit of nitrous and not planing to run mad boost so alot of waste gas will need a good free route to escape
    I will start a thread on manifold build, may be usefull to some people
    Here is the new gate and 50mm BOV
  9. benny Forum Member
    Porn!
  10. benny Forum Member
    Do you do a root then a cap then Bill?
  11. badger5
    nr Glos
    on the sch40 stuff yes. on sch10 no.
  12. benny Forum Member
    I didn't know that, ta! :thumbup: I'm just doing a TIG course, struggling a bit, practice, practice!!
  13. badger5
    nr Glos
    its all practice and some decent kit.. and tips off others who are far better at this then me..
    I am waiting on some gas lenses now to help keep a nice shiney weld on stainless.
  14. badger5
    nr Glos
    small update
    update:
    getting there...
  15. benny Forum Member
    Like! :thumbup:
  16. Dclarke Forum Member
    Love that inlet - got anymore in stock? ;)
  17. 16valver Forum Member
    x2 - are they available?
  18. badger5
    nr Glos
    SEM, they are available yes. largeport and smallport versions $825 plus shipping & tax etc in std form.
  19. 16valver Forum Member
    What is the lead time?
    I thought there were problems with supply and SEM only doing a batch when they had enough orders?
  20. badger5
    nr Glos
    supply has outstripped demand yes, and tail end of last year they had run out, and were getting another cast qty together.. which was supposed to be early 2011
    what spec would you be looking for, and I can confirm status
