gti 16v kr fuel pressure accumulator alternative
Discussion in 'K-Jetronic OEM injection' started by dub_fever, Nov 13, 2018.
  1. dub_fever Forum Member
    I believe the VW part number for this is 431133441c, does anyone know if I can use one from an alternative car or can I only go with this one.
    reason for asking is because some places online are charging £150+ so would be good to know if I can save myself a few quid.
    TIA
    rubjonny Administrator Admin
  3. jamesa Forum Junkie
    Abz
    You could also try ...
    http://www.kmipetrolinjection.co.uk/
    http://www.golfmk1.co.uk/
    I have a similar, new unit that I would sell ... only difference is that it has an outlet port at the base. This is to provide relief should the internal diaphragm rupture (I was going to run a hybrid fuel pump / accumulator system inside the car).
  4. jamesa Forum Junkie
    Abz
    Bosch part no. 0 438 170 029
    I also have for sale ... a new pump and pump / accumulator connecting hoses purchased from the above sources ... if required.
