Guide: Retro fit cruise control to MK3 Golf TDi
Discussion in 'Diesel' started by Dubnutter, Sep 21, 2011.
  1. rubjonny
    mk1 and mk2 cruise stalks are electrically identical to mk3 :)
    the pre-90/mk1/scirocco ce1 stalks haver a different plug on but still work, the ce2 mk2 stalk has the same plug on so pops right onto the tdi connector :thumbup:
  2. DN5
    DN5 Paid Member Paid Member
    Doncaster
    Absolutely brilliant! Cheers Rubjonny. If using the mk2 diesel clocks however as I plan to do eventually would I need a speed sensor somehow?
  3. rubjonny
    yes you need to make sure the clocks you buy have the ability to add the speed sensor to the back of the speedometer, you should see a spare bit of blue ribbon foil with 3 pins on it :)
    mk2 petrol clocks could be used on a TDI with the same type of tacho adaptor that the 20v guys use as well, so thats another option worst case
  4. niki_can133 New Member
    Can you help me, I drive Audi A4 B5 APU engine. I did the same thing as show in this topic, cruise control works great but when I go on downhill, the car doesnt use brake to keep the same speed 80 kph, and go over it. Is this a problem or its normal. Thank you.
    P.s. I know this is vw forum but noone want to help me in audi forum.
    P.s.2- Sorry fot my English
  5. m1keh Forum Member
    Its normal.
