Hello everyone, Nice to be back in the AGG MK3 camp. Just installed one of these into my VW campervan and ironing out rough idle issues. I hooked it upto VCDS lite and getting these errors and readings from measuring blocks: Can anyone shed light on these? Lambda goosed? Timing out? Thanks
17978 is immobiliser code, so you can ignore that one. dizzy timing looks to be out, adjust the distributor while you watch group 7 blocks 1 & 2: 1 - 57-60 or 1 2 - 5 - 8 then once sorted clear the fault codes to see if the lambda comes back after a drive
Managed to adjust my timing today, what is the 'ideal' setting? Does say 57 / 5 make any difference over 1 / 8? Thanks
